Capacitors...
Old Mar 11, 2003 | 10:47 PM
dennis's Avatar
Capacitors...
I'm looking for a 1 farad cap. I'm basically pushing 800 watts to my subs and my head lights dim slightly. Am I going to need more than 1 farad? What are good brands? Which brands are the best "bang for the buck"? How much do they normally run? Thanks.
Old Mar 11, 2003 | 11:18 PM
Nicky Pass's Avatar
Fuct in the hed!
A cap really won't help light dimming. A caps purpose is to supply your amp with power during big bursts. To keep the lights from dimming you'd probably have to upgrade your alternator and battery!
Old Mar 12, 2003 | 02:02 AM
dennis's Avatar
What does an upgraded alternator go for? What size is stock and what size would I need for an after market?
Old Mar 12, 2003 | 03:26 AM
03acura's Avatar
9th Gear
Capacitors
A 1 Farad Cap will be sufficent for the dimming of your headlights. The reason your headlights dim, is because the amp draws more power from the altenator at times of low bass response. The altenator on a cl is 120amp standard. That is really good compared to other vehicles. The cap stores energy up to 14.4 volts and releases it when the bass hits. One of the best caps to get is a lightning cap or stinger. Any brand will do just fine! Have fun
Old Mar 12, 2003 | 09:45 AM
SlyTLS's Avatar
Bada Bing
I agree with 03acura...a cap will solve you're problem. A good brand to use is Alumapro. I'm running 4 amps pushing over 1,500 watts off an Alumapro 15 farad cap and I have no electrical issues at all.
Old Mar 12, 2003 | 03:00 PM
shawhite_RENAMED's Avatar
if you are gonna get a cap definately go with the alumapro caps....
Old Mar 12, 2003 | 03:13 PM
Nicky Pass's Avatar
Fuct in the hed!
My head lights never dim...its usually the dash lights and interior lights that are affected by the system!
Old Mar 19, 2003 | 06:39 PM
wetb00's Avatar
Only Broke CL member
ok i am running 1600 watts in my car back in hawaii its has two caps and doesnt have any problem my friend has a tahoe same set up no caps lights dim i am running rockfords dennis IM me dahawaiianbarney AIMsn i have a shop you can go to i work there when i am not in california
