Can you multiplex two inputs into am amp?
Old Apr 14, 2005 | 02:11 PM
Bxscig's Avatar
Can you use something like a Y RCA cable to multiplex two inputs from like a HU and a Ipod (Some other device) to an amp? I am not sure if this would cause noise or if it is even recommended.
Would using a relay to switch between the two inputs be another solution?
Old Apr 14, 2005 | 11:20 PM
elduderino's Avatar
VP Electricity
You are somewhat misuseing the term "multiplex".
No, you shouldn't ever do that - the outputs often interfere with each other, even when not on.
Many switchers use relays or ICs to do this -Soundgate and PAC have them, and Peripheral. Check Autotoys.
Old Apr 15, 2005 | 12:48 AM
DerrickM's Avatar
I wouldn't recommend using relays. I soldered up one with RCA jacks and a transister gain to power the relay, and I found the contacts in the relay affected sound quality (even when the coil was not energized). I would buy something like Eld. recommends, rather than build one.
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
thegipper
Sep 28, 2015 01:01 PM
