TL: Buzzing/whining after sub install...help!
Old Apr 19, 2013 | 10:19 AM
TL202's Avatar
I recently installed two 12" subs with an amp and now i get loud obnoxious whining noise. It dies down only when i turn the volume up...ive tried re grounding the system and the head unit itself. Nothing seems to help it what so ever....
Any thoughts?????
Old Apr 19, 2013 | 12:17 PM
pcass1231's Avatar
3rd Gear
It sounds like it might be road noise or interferrance. Make sure the power and the remote wires are as far away from the RCA's as possible. That should fix the buzzing sound.
Old Apr 26, 2013 | 09:12 AM
victus1's Avatar
Does the whining sound change with application of the gas pedal? If so, you have a ground loop problem. You need to ground your head unit and amps directly to the -ve terminal of the battery.
