Burning MPEG DVDS
Burning MPEG DVDS
trying to put all my music videos onto some DVD'S but having a hard time doing it. can you guys help me out ? if anyone knows how???
i tried using nero but it failed for some odd reason.
and o ya its for playback on a pioneer double din if that makes a difference.
thanks fellas.
thanks fellas.
Need some more info! I do this all the time with various videos. First of all, what kind of files are they? Are they vob, avi, mpeg, mpg, m2v, etc.? Depending on what type of file it is, it will determine how many steps are required to burn them onto a dvdr and what programs are required.
aw crap. hey man thanks for looking out.
so all my files are MPEG maybe a couple are MPG, dont know if thats the same thing. and also, I have a couple that are AVI. what head unit do you have? do you know if the pioneer will play these files???
thanks alot. appreciate it.
The head unit doesn't really matter. As long as it could read burned dvds you should be ok. Depending on the resolution, mpeg or mpg are compatible with dvds. The next thing you need to do is find out what the resolution of the videos are. The supported resolutions for NTSC dvds are 352x240, 352x480, 704x480, 720x480. The supported resolutions for PAL dvds are 352x288, 352x576, 704x576, 720x576. You can not mix PAL videos with NTSC videos. The whole dvd must be PAL or NTSC. Most media players (Windows Media Player, Winamp, VLC Player, etc.) will tell you this information. Hopefully, your videos fall in these resolutions. Once you figure this out, it will determine your next step.
ok sounds good so far. my room mate is going to be doing this for me so let me talk to him and I ll get back to you. how do I read the resolution of the video on windows media player? Im playing a video right now but I dont see anything about resolution. appreciate your help. alot.
thank you.
thank you.
Ok ya, my room mate figured out how to display the video resolution. Im one step closer to getting this to work, thanks again.
Would you please tell me what the next step is now??? What program do I need to actually burn the videos?
I dont know where your located but if you want to pick up the phone and call me to make this easier, I would more than appreciate it. P.M me if so.
Thank you again.
Ricky
Thank you again.
Ricky
The next step will depend on the resolution of the video. If it falls within the resolutions that I outlined, chances are it can be burned onto a dvd. If not, they will have to be reencoded to dvd standards.
Nero assumes that you already have all the videos in a dvd file structure. First you need to reencode the files if they are not dvd compliant. If they are compliant it will take alot less time because you will not have to reencode. This is a program that I use:
TMPGEnc DVD Author
The program has a trial period. If you can't figure it out, let me know and I will help you.
TMPGEnc DVD Author
Hey thanks again master. I ll give it a whirl tonight and let you know.
Appreciate your help. Im having my dvd/sound system installed on thursday so Im really anxious. =)
Talk to you later.
Thanks.
Talk to you later.
Thanks.
calrow
05-03-2017 10:21 PM
