Broken Deck
Old Sep 20, 2002 | 06:34 PM
dnd2984's Avatar
Broken Deck
On monday my deck wouldnt fold back into the dash when i turned my car off so the audio place ordered a new one. So today it came in and they got it installed and it wouldnt open up all the the way. So now Alpine # 3 is on its way....
Old Sep 20, 2002 | 07:39 PM
Well before you go blaming it on Alpines quality....make sure that your installers are just stupid. I've put in my share of CVA-1000's, CVA-1005's, CVA-1006's and CVA-1003's. The problem of the unit not opening fully can be caused by (A) The iso mount screws on a CVA unit being tightened down to tight, causing pressure to be put on both sides of the unit and either causing the unit not to open/retract or to prematurely fail (B) The same thing can be caused if a trim ring of some sort is made and it is not large enough for the unit to fully open close without contact. Basically the trim ring puts pressure ont he unit while it slides in-out. Just an FYI for yah.
Old Sep 20, 2002 | 08:17 PM
dnd2984's Avatar
I never said I was blaming Alpine, or anyone else. ITs just back luck and I have alot of it. THe deck worked fine for about a month. This is one of the best install place in FL. The first time the deck fell off of track. My trim is pretty big acutally, the deck is just enough flush mounted so it wont stick out.
Old Sep 29, 2002 | 07:08 PM
http://clubxm.com/phpBB/viewtopic.ph...989&forum=10&7
Check the link...it may have your answer. Scroll to bottom of post...good luck.
Old Sep 30, 2002 | 10:21 AM
dnd2984's Avatar
Thank you that helped. O and now I am on Deck # 3 and Deck # 4 is on it way. the deck wasnt made for a angled dash and when it was layed flat it functioned fine. THis must me alpine 1st bug.
mlody
Dec 4, 2019 02:11 PM
juanrl
Sep 29, 2015 03:25 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
Sep 25, 2015 06:05 PM
rboller
Sep 23, 2015 02:49 PM
