Blitzsafe install in 3 minutes on CL
Old Oct 1, 2006 | 12:28 PM
Zackb911's Avatar
You guys had me scared to install my blitzsafe. I did a search and came across people talking about what a PIA it was and battle scares, well I got mine installed in 3 minutes start to finish
1. Remove wood trim from armrest to radio by just open armrest and pull up, no prying with screwdriver .
2. Remove 3 screws on right side of the sifter console, these are the ones that hold the passenger trim on the side of the console on.
3. Now the side of the radio is visible and I think this is where many run into problems, the trick I found was; while looking at the passenger side of the radio you will see a metal bracket on the lower right with a small opening behind it, feed the blitzsafe connector in from there, with your other hand just guide it into the socket in the back of the deck, it will line up perfectly and feed to the right spot .
4. Put everything back together...
This literally took me 3 minutes on the first go. The trick is in guiding the connector in from behind that bracket, when you try feeding it in from under the deck, which I think is what most do, the angle makes it REALLY hard to get connected.
Zack
Yikes
May 3, 2021 04:29 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Billu99tl
Sep 13, 2015 11:30 AM
ivegotthenav
Sep 11, 2015 07:51 PM
NSolace
Sep 3, 2015 08:14 PM
