Best way to cut the doors?
How do you guys think the best way to cut the doors for bigger speakers is? A dremel with a reinforced cutting wheel? Even though I am cutting the door I still want it to be as clean as possible. I have primer to put on the edges afterwards t. The whole area will be covered up with matting after the fact but I still want to know that its nice and clean under there. I'm not sure if the dremel reinforced cutting disks will do the job what do you guys think?
thanks
Mike
thanks
Mike
dremel, air saw,sawsal, jigsaw,tinsnips. all will work. dont use just primer, primer wont block out moisture. use paint.
mlody
12-04-2019 02:11 PM
soupi
14
11-15-2015 11:15 AM
polish_pat
09-25-2015 12:24 PM
