aux audio input for 2002 TL w/ Navi + 6 disc in-dash
'06 NBP : 6MT : NAVI
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I have done a ton of searching and have been unable to find a definitive answer to my question. Which, if any, aux audio input should be used with a 2002 3.2TL with navigation and 6 disc in-dash changer?
Both the Blitzsafe and P.I.E ones say they're not compatible with navigation and/or in-dash changers.
Thanks for your help.
Also, with Dom's rgb converter (TVandNav2Go), is the installation the same as in a 2004+ TL? i.e. video can be tapped either in the trunk or at the passenger kick panel area?
Thanks,
Mike
Thanks,
Mike
Just purchase the Blitzsafe adpt. it works with Navi etc.. And I haven't seen anyone install Doms converter in the kick panel area on either the TL or CL 2nd gens..
Thanks, this is actually for an install on a friend's TL. I just wanted to make sure that I tell him to order the correct adapter.
Jonesi, what part of pittsburgh are you from? I'm from pittsburgh originally, but have been working in CT since June. I'll be moving back to pittsburgh this coming June, which is when I plan on getting an 06 TL (MT w/ navi).
Do you have experience with any of the area dealers? I took a test drive at Spitzer.
Mike
Mike
I'm up North in Cranberry.. About 10-15 minutes outside of Pittsburgh..
I've always had good experiences with Baierl Acura. They are in Wexford. But I've also heard good things about Spitzer..
One more quick question. Jonesi, you said that you haven't seen anyone install Dom's unit in the passenger foot area, right? Is this because the wiring harness doesn't run through that area?
Basically I want to put the rgb converter in the front of the car and not have to remove the head unit to do so. I'm trying to avoid running power and signal wires to/from the trunk.
Any thoughts?
Thanks,
Mike
Any thoughts?
Thanks,
Mike
You can find the power and signal wires in the trunk..
https://acurazine.com/forums/audio-video-electronics-navigation-22/diy-doms-nav-dvd-install-w-pics-2000-tl-312145/
The TSX guys have installed in the kick panel but no one has attempted it on the CL/TL. I have a Helms manual but never looked to see where the wires are ran to the trunk..
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
