TL: Anything in stick 00' TL + subs
Old Jan 24, 2011 | 05:38 PM
troper24996's Avatar
Are there any guides or instructions..(I HAVE LOOKED IN THE STICKY)..FOR 2g TL (non-navi) sub+amp installations using (STOCK) HU?
-I want to add some base..do the work myself..but am new to wiring in my TL.
anything is appreciated thanks
Old Jan 24, 2011 | 07:03 PM
Jimmay's Avatar
All youre going to do is use a Line out converter. You can get the signal off the rear sub in your deck(if you have one) or the rear speakers. If you have a rear sub i would disconnect it and just run the one(s) you plan on adding.
You can use the remote turn on for the stock amp(assuming it is back by the trunk). I have an RL so mine was in the rear. The installation of a LOC is basically standard.
There are various threads that have the information in them on how to install subs in a TL.
Old Jan 24, 2011 | 09:12 PM
eggyhustles's Avatar
don't use a pos loc
99% of them have a limited bandwidth.
Old Feb 11, 2011 | 04:03 PM
Holliewood's Avatar
9th Gear
can i ask you are you hooking up an amp as well? cause i would like 2 know what i need to run an amp?
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
