Anyone replaced the door speakers and not the amp.?
OG
I am just wondering because I want to replace the speakers in my wife's MDX with some decent speakers. Since the MDX's system is similar to the TL's, I am just wondering what your experience is. I remember someone said that the stock headunit puts out about 12-15watts rms to the door speaers, if that is so, it should be enough to drive most, if not all aftermarket speakers, even high-end ones.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
My AcuraTL Homepage
i know there is a user who rarely posts that did it (i didnt have a chance to talk to him)
there is a user on the cls board that did it and said the results were amazing
Yeah,
I need to know as well. There's some excellent 6.5" 3-way speaker on the web, but didn't want to buy unless I was sure it would work. DON'T WANT TO REPLACE ANYTHING OTHER THAN THE SPEAKERS!!!No HU or amps or purchase a line-out converter. Just speakers! This modding bug is getting out of control...can you say crack!
I replaced all of my speakers with Boston Pro's. It sounds nice but I am definately getting an amp to push them. Running right off the deck just does not give them enough power. Also these are the same Boston's that I had in the truck when they were pushed with a Xtant amp.
1998 3.2TL Satin Silver
Tinted Dark!!
HID headlights
Boston Pro 6.4's all the way around
Short Ram Intake
Tinted Dark!!
HID headlights
Short Ram Intake
If the speakers are 1 ohm ( I have no clue if they are), then there wont be enough power to push any aftermarket speaker. Almost all aftermarket speakers are 4 ohms, that means only about 3 watts per speaker. I never heard of any speaker that ran with only 3 watts and sound good. Hope I'm wrong though, cause replace stock speaker would be alot easier.
99' Taffeta White TL
Fosgate Power 800a2
Two 10" Hx2
E750s Lanzar Preamp
Titanium Tint
Fosgate Power 800a2
Two 10" Hx2
E750s Lanzar Preamp
Titanium Tint
A friend of mine just added tweeters to the stock set up and they work perfectly. I don't know if the zohm load would affect a tweeter but if he got it to work then I think any speaker except infinity Kappas and Polk DBs etc that need a minimun of 8 rms would sound great. most aftermarket nedd at least 2 rms. I think the Ohm thing ws different when acura used the Bose speaker that were amped at the speaker itself. If we have an amp I dont think it would push a 1 ohm load. Maybe just the sub woofer. Is there a way to measure the ohm load at the speaker terminals? Streeteffectz are you there?
OK just checked out my stock speakers and they are printed on the back 4 ohm. I measured them with a Fluke Multimeter and it read 3.8 ohm. So close enough...4ohms
OG
Thanks. That's pretty good. Most highend speakers, including Boston Pros are rated at 3ohms. That means it will make your stock amp kick out extra power, hope the stocky can handle it though.
OG
Originally posted by NighthawkBlack:
Wasn't that your idea? Now you are contradicting yourself? Why the suden change in mind?
Guest
Posts: n/a
You're kind of in the wrong place for this anyhow. Your assumption that the TL and MD-X systems are similar is bad. The TL has an external EQ that gets pumped back into the head unit and amplified. Then 4 channels of speaker level output go to the door speakers, and one channel of line level goes to a separate amp for the sub woofer.
For the MD-X it depends weather you have the premium sound system or not.
For base sound system:
The MD-X head unit puts out 4 channels of line level that goes to an external amp/eq. The amp puts out 4 channels of speaker level (the tweeters run off of the front door speaker line). The rear passenger side door speaker is tapped to another amp which feeds the sub woofer.
For the premium system:
The head unit puts out 4 channels of line level to an amp that puts out 4 channels of speaker level and one channel of line level. The speaker level signals are routed the same as before, but the 5th channel is then routed to the sub woofer amp. The sub woofer amp then feeds the sub and the rear roof tweeter.
You can replace the amps for either MD-X system, but good luck fitting a new one into the space of the old one!
P.
P.
I have an MDX with the base (non-Bose) system. Looking at the Helms manual, it appears that, contrary to the previous post, the amplifier for the front and rear speakers are built into the head unit. This would mean line level signal for an external amp is not easily available. If this is incorrect, please respond, since I would love to upgrade the amps.
WOW I just put in my Clarion Auto PC and hooked them up to my Boston's and WHOA what a difference from my stock deck. Sounds 10 times better. The Auto PC is rated at 35x4 but of course that is still deck power. I should be getting my Rockford amp hopefully by Friday so I can install it this weekend.
AndrewS
19
03-14-2024 06:59 PM
handsom-hustla
11-13-2015 05:04 PM
alan_rich
09-07-2015 11:08 PM
