Antenna question
Old May 30, 2007 | 10:47 AM
mrchan625's Avatar
Antenna question
since we dont have any antennas visible on our cars how do we pick up our radio signals?
I just installed my Kenwood KVT-715 everything else works but the radio and im starting to think that it might be an antenna problem. So just wondering if anyone can give me some help?
thanks in advance
Old May 30, 2007 | 01:17 PM
mercman's Avatar
I don’t know what car you have but most cars use an antenna amplifier that is powered via the factory harness (factory HU). You need to find it and see if it is powered. A lot of aftermarket wiring harnesses do not include this pin. You can use the “Power Antenna” wire from your new deck to feed it. Again, without knowing your specific wiring I can’t tell you what wire it would be.
jeff
Old May 30, 2007 | 11:24 PM
mrchan625's Avatar
well i have a 99 tl a friend of mine actually installed the head unit for me was there a certain color for the factory antenna? sorry im ind of a noob at this
Old May 31, 2007 | 02:13 PM
soccerbenk's Avatar
yesss i need to know this as well what color is the factory antenna amp that i need to power?
Old May 31, 2007 | 09:41 PM
uncald4's Avatar
Former Sponsor
Before this turns into rocket science......
Almost every Metra harness has an "Antenna TURN ON" wire. It's blue. Some Metra harnesses have both an ANTENNA and AMP turn on wires. Most aftermarket deck harnesses have a blue wire with a white stripe that will turn on either of these factory options. Some aftermarket decks have seperate ANTENNA and AMP turn on wires.
For your TL... the Metra harness will have a single blue wire. This will turn on both your amplified antenna and your factory subwoofer amp.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
