Another Video on navi thread
Old Feb 28, 2003 | 06:50 PM
Greg D's Avatar
OK guys... Heres my dilema. I recently purchased an AVC-RGB1 navi kit that was made my SteveSTMS, back when he was originally selling them. Does anyone have the exact instructions he used to include with the kit? Im not looking for the ones other people designed, im looking for the exact ones he included with his kit originally. Can anyone help me out?
Old Mar 2, 2003 | 12:19 AM
StanMan's Avatar
i did the avcrgb1 conversion using instructions from TYPESDRAGOON...you can find him on a-cl and the link is in his sig.
Old Mar 2, 2003 | 09:10 AM
calvinpham74's Avatar
i will have typesdragoon install the avcrgb1 for me on monday. Here is the link of what he write on it. http://www.angelfire.com/super/types...onversion.html
hope this will help.
Old Mar 2, 2003 | 11:50 AM
BDI's Avatar
BDI
Maybe Arn200tl has steve's original instructions.
Old Mar 2, 2003 | 12:01 PM
ArN 2000 TL's Avatar
Moderator Alumnus
For some reason I think he deleted his original post on the instructions, but I have it printed out somewhere I think, but if not I will do a write-up on it for doing it from the back of the car via the navigation unit plugs (easier is you ask me).
Old Mar 2, 2003 | 12:14 PM
Greg D's Avatar
Well, I can use those because the wire colors are the same in the front and the back. I do want to install the kit in the trunk, but it is already modified with the short wires, to mount behind the nav. I really dont want to open it up, and re wire it. The reason I wanted his instructions, was because He picked these wire colors, and he knew where they went. The wires are: Display connector: white, red, green, yellow
Wire Harness: white, red, green, yellow
Then 3 brown and green wires ( which Im assuming are 12+, key on, and ground. Then one lone green wire (which I think is the parking brake wire) Any thoughts?
Old Mar 2, 2003 | 12:54 PM
BDI's Avatar
BDI
Yup the long green wire should be the parking wire. Just ground it.
Old Mar 2, 2003 | 12:56 PM
Greg D's Avatar
We dont need the yellow ILLUM wire right? That one can be cut off?
Old Mar 2, 2003 | 01:59 PM
Moderator Alumnus
Correct. You can still mount it in the trunk though even with the short wires because you can attach it to the rear deck. The only downside is running the RCA's all the way to the back (isn't a big project, but way easier than taking apart the dash
Old Mar 2, 2003 | 02:40 PM
Greg D's Avatar
i figured Id mount it in the front, because it would be easier to do then extending the wires for the switch. I dont mind running the rca wire, because since I am going to mount the DVD player in the trunk anyway, I will have to run audio RCA wires to the blitz adapter i nthe front. Were you able to find those instructions?
Old Mar 2, 2003 | 02:49 PM
Moderator Alumnus
Not yet...i'll look when i get home. If not I will scan in the wiring diagram from the Helms wiring diagram and label all the wires you need to splice into.
Old Mar 2, 2003 | 02:56 PM
Greg D's Avatar
Cool. Thanks. Do you where each wire coming off of the decoder goes to? Thats why I wanted Steve's instructions. Since he built it, he would know which wires went where.
Old Mar 2, 2003 | 03:38 PM
Moderator Alumnus
I just looked around and unfortunately I was unable to find them. Either way, I don't know what Steve used as his color code for each of the wire so I wouldn't be able to tell you which wire went where. Streeteffectz might have them because he was the first one who bought his kit.
Old Mar 3, 2003 | 05:58 PM
thescoundrel's Avatar
I made a copy of the old instructions just pm with your address and I will send you a copy of the instructions and pics that were posted...
Old Mar 3, 2003 | 07:14 PM
Moderator Alumnus
If you wouldn't mind, please post them in this thread so other members that need it can reference it....thanks!
Old Mar 5, 2003 | 12:33 PM
If i was a premium member i would post the pics and files; but since I am not I can only send them to those who ask for them...
Old Mar 5, 2003 | 01:35 PM
Moderator Alumnus
Send them to me and I will post them up. Thanks!
Old Mar 5, 2003 | 02:09 PM
Greg D's Avatar
These are the directions made by TypeSDragoon I believe, I don't think these are the ones Steve made
Old Mar 5, 2003 | 06:48 PM
i just got install by typesdragoon. It was complicated. it took him 6 hours to do all the install. it worthed though. it took me two hrs to drive to his house, but it worthed everything. Now i just need to buy the head rest and I am all set to go.
bymotion
Nov 18, 2015 11:28 AM
navtool.com
Sep 25, 2015 05:15 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
Gianni Formica
Sep 7, 2015 08:28 PM
