Amp Problems....
Amp Problems....
Ok, My AMP Kinda Died on the way into work. Wasn't even Close to overpowering it. The Power LED Fases in and out, but if I disconnect some of the channels and hook them into the Pre-AMP 1/2 3/4 Inputs instead of the normail 1-1 2-2 3-3 4-4. The power will come back on.
But If I disconnect all channels the power starts fasing in and out again. If all channels are hooked up properly it doesn't work, only if I set it up in a odd config. I tested all the speakers and there is no short since the all work if I swap the wires around.
I'm thinking 1 or 2 of the channels went bad, or the power supply in the AMP went bad if all Channels are hooked up.
Any IDEAS?
THanks
Any IDEAS?
THanks
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
Pegon95
09-15-2015 01:54 PM
