TL: Amp power connection to battery
Old Jul 26, 2012 | 09:01 PM
dbsanders's Avatar
I want to run 4 gauge wire to the battery. The new terminal that came with my wiring kit has connections for one 0/1 gauge and two 4-gauge connections. However, my stock terminal connector seems to already have two large wires connected, not sure what size.
To try the new terminal, I'd have to cut off the old ring terminal and try to stuff the two large wires into the 0/1 - doesn't seem like the best idea.
What else can I do? Will a ring terminal around the tightening bolt be a good enough connection for 80A?
2003 TL, non -S
Old Jul 30, 2012 | 06:35 PM
Xcepticus's Avatar
8th Gear
Your best bet is to visit an AutoZone store and ask if anybody can help you regarding that issue. Pepboys may tell you to pay have it installed...
Posted from Acurazine.com App for Android
Old Jul 30, 2012 | 09:21 PM
dbsanders's Avatar
Yeah I looked around a bit more and I found out that the existing stock wires are only 4 gauge, so I put new ring terminals on them and also replaced the battery terminals. Then attached new 4 gauge wire for my amp. Worked fine, now just have to find a way to cover the positive battery terminal, as the old cover doesn't fit with the three different wires going in three directions!
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
Rob144
Sep 21, 2015 08:18 AM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
