TL: Which amp to buy?
Old Jun 20, 2009 | 02:51 PM
Eddystone's Avatar
Which amp to buy?
I am looking to buy an amp to use with the factory sub and speakers. I was told my a friend that will be installing it to buy a 5ch amp. Now, what brand and model should I buy? I dont want to spends hundreds only something decent.
Old Jun 20, 2009 | 03:13 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Definitly go with aftermarket speakers and sub with your 5 ch.Your speakers ohms will not match your new amp.It will probally sound worse or with too much power you'll smoke your speakers.
Old Jun 20, 2009 | 03:25 PM
on1wheel01's Avatar
+1
Old Jun 20, 2009 | 03:30 PM
Eddystone's Avatar
Ok, but what amp would you guys recommend?
Old Jun 20, 2009 | 03:55 PM
How much you looking to spend thats the biggest question.Then how much power do you need.Any cheap 5 channel will get loud.Quality comes with cracking the wallet.On the cheap side 150,Nice amp 3-4-5-$600+.
Old Jun 20, 2009 | 03:58 PM
Eddystone's Avatar
I am probably going to buy a used one for about $200 or less. Not sure what I should be looking for.
Old Jun 20, 2009 | 04:06 PM
If you get one thats has atleast 75w rms for the 4 speakers and atleast 3-400w rms for sub.you will notice the differance.You'll be satisfied if your not a person that cant get enough bass like me.the lower the THD #'s that the amp has will give you beter sound quality.I could be wrong ,but I dont think so
Old Jun 21, 2009 | 07:45 PM
mattastick's Avatar
The lower the THD numbers, the cleaner the power the amp puts out... So if it does 200w at .05% THD compared to 200w at .1%THD, the first amp is not going to clip as much, and will help to prolong the life of your speakers...
OP, you're going to see more change in sound quality by replacing the front speakers with a decent to good component set and a small 2 channel amp to power them, rather than amping all of your factory speakers and sub...
Old Jun 23, 2009 | 09:37 AM
BT5150's Avatar
If you are going to go with a 5 ch amp, I'd check out this one:
http://www.sonicelectronix.com/item_...+ZXi+8010.html
I've had several HiFonics amps over the last 10+ years and have always had good luck with them.
Old Jun 24, 2009 | 06:15 AM
on1wheel01's Avatar
or if u wanna run 2 amps one for just subs u can buy mine lol but it's prolly way to powerful for what u have
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
iesu3423
Sep 29, 2015 08:04 AM
navtool.com
Sep 25, 2015 05:15 PM
