Amp / Battery Question
I have a small system, 400W amp pushing 1 10" sub. I noticed the lights dim when the bass hits. I'm running the OEM battery which is about 2.5 years old now and seems to be getting a little weak. I plan on replacing it before the winter, so heres the question. Is an Optima RedTop good enough for my system or should I get a Yellow? I'm concerned about frying the alternator or other things since I had problem in other cars, and the lights dimming tells me theres not enough power to go around. And this was at modest volume and the gain is almost all the way down. I also heard that upgrading the battery to chassis ground wire would help, is that worthwhile? I'm not looking to go crazy, just don't want any problems.
Thanks guys
ps- please dont say "search" cause its not working
Thanks guys
A red top would do you well, but I'd suggest an Odyssey battery over Optima. Same price or a little bit less, and these seem to be what the experts recommend now.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
A red top would be fine, if you don't wanna drop the money, get a capacitor, a 1-1.5 farrad should suffice for 400w
Thanks guys! The battery is definately getting replaced, system or no system since OEM batteries are garbage. I'm not really looking to install a cap, though I'm sure it would help. Hopefully the Redtop is sufficient to eliminate the dimming. And if not, I read elsewhere that larger gauge ground wires from the battery and alt would help too, so I'll see how it goes. Thanks again.
(Mid-Atlantic)
(Mid-Atlantic)
8 is a big enough wire for 400w. Try the redtop first, if that doesn't work, do the wire upgrades, for a system that small you shouldn't need a cap
mada51589
05-03-2022 08:54 PM
BoricuaTL
04-08-2016 01:08 PM
Pegon95
09-15-2015 01:54 PM
