alarm shock sensor - need to locate a wire
Most of us hooked up the shock sensor to the hood trigger wire (yellow w/ silver stripe). Anyone with a Helm manual, can you point out which is the TRUNK trigger wire? (color code, where can it be found etc would be extremely appreciated. THx.
wire
http://www.acura-cl.com/forums/showt...threadid=70963
Go to this link. someone posted this info. Can u locate the hood trigger wire for me exactly. I looked in the pass fuse box, and there are several yellow wires dont want to use the wrong one
If you already have CompuStar installed, you dont wanna add shock sensor to stock. In case both shock sensors (stock add-on and CompuStar's) are triggered, you are gonna go crazy because of the horn and the siren.
Re: wire
I gave up on the trunk wire though I think when I need to do something with the trunk, I just hit the open door (alarm off) button and pop the trunk and do whatever...it too much trouble searching for that wire.
cycdaniel
12-17-2019 10:58 AM
