Alarm/RemStart/VSS Wiring Info for TSX
VP Electricity
1 Post
2004 Acura TSX
Vehicle Wiring Information
(Asterisks refer to numbered notes below)
| ITEM | WIRE COLOR |POLARITY| WIRE LOCATION |
| 12V| white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|pink/black *1 |- |grn plug, L side of fusebox |
| POWER UNLOCK|pink/blue *1 |- |grn plug, L side of fusebox |
| LOCK MOTOR|yellow/black |5wi|grn plug, front of fusebox |
| UNLOCK MOTOR|yellow/green |5wi|grn plug, front of fusebox |
| DISARM DEFEAT|yellow |5wi|large wht plug above fusebox|
| PARKING LIGHTS +|red/black | |large wht plug above fusebox|
| PARKING LIGHTS -|blk/red or blu/red | |in steering column cover |
| HEADLIGHTS|blk/red or blu/red |- |in steering column cover |
| DOOR TRIGGER|green/red |- |grn 5 pin plg behind fusebox|
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|blue/black |- |driver kick, harness to rear|
| HOOD PIN|yel/red or grn/blk |- |hood pin switch in latch |
|TRNK/HTCH RELEASE|yellow/green |+ |driver kick, harness to rear|
| FCTRY ALARM ARM|white/red |- |driver door module in door |
|FCTRY ALRM DISARM|white |- |driver door module in door |
| TACHOMETER|blue | |ECM/PCM *2 |
| SPEED SENSE|blue/white | |ECM/PCM *3 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|green/yellow |- |steering column |
| WIPERS|blue (L), yellow (H)|- |windshield wiper motor |
| LF WINDOW UP/DN|red/blk - red/yel |A |LF window switch in door |
| RF WINDOW UP/DN|red/blu - red |A |RF window switch in door |
| LR WINDOW UP/DN|red/wht - blu/blk |A |LR window switch in door |
| RR WINDOW UP/DN|red/wht - blu/blk |A |RR window switch in door |
| SUN RF OPN/CLOSE|grn/yel - grn/blk |A |moonroof motor, rear of roof|
| RADIO 12V|white/blue |+ |radio harness |
| RADIO GROUND|black |- |radio harness |
| POWER ANTENNA|yellow/green |+ |radio harness |
NOTES:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when
adding remote start. Use DEI part number 555U.
*1 These wires will meter when using the passenger door lock switch.
*2 The ECM/PCM is on the front of the transmission tunnel. The connectors
are on the passenger side. The tach wire is in the white 31 pin connector E, pin 25.
*3 The ECM/PCM is on the front of the transmission tunnel. The connectors
are on the passenger side. The VSS wire is in the white 31 pin connector E,
pin 26.
*4 The stereo amplifier is in the center console, below the radio.
IMPORTANT: This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility
to verify any circuit before interfacing with it using a digital multimeter.
NOTES:
pin 26.
SUPRMN84
10-07-2015 09:46 PM
Eggs999bacon
09-24-2015 10:08 AM
