Alarm install help...
I have installed a Clifford RSX3.5 in my TSX and having problems disarming the factory alarm with the Clifford remote. The factory alarm will eventually disarm if i keep pressing the unlock button on the Clifford after the horn goes crazy. I have not hooked up the Disarm defeat wire because I am not exactly sure how this works. I have the factory arm and disarm wires hooked up from the driver’s door. Do I need to pulse the disarm defeat wire when the unlock button is pressed? I have tried extending the pulse and double pulsing and cant seem to get this to work. Any help would be greatly appreciated...
Thanks Eld, I figured it out. I had the factory disarm wire hooked to the seconary unlock output instead of to the factory disarm on the main unit. Everything works great now! Thanks for the help!
