Alarm goes off randomly
Old 11-04-2008, 05:15 PM
7th Gear
emotovilov's Avatar
I have an 1998 3.0 CL. Alarm goes off randomly now and then when car is locked. If I remove the fuse, car wont start. Wondering if I can disable the alarm at the source. Anyone know how to fix or how to disable it?
Old 11-04-2008, 05:40 PM
N00berator
MoSp33d's Avatar
The issue can be anything from a too sensitive shock sensor, to an electrical fault in the vehicle which is letting off the alarm, to a defective alarm unit itself. Best betwould be to take it to a pro. and have it checked out.
Old 11-05-2008, 08:33 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,462 Likes on 3,056 Posts
Can also be your key fob dying, change it's battery, but also check the contacts on your doors, and hood
Old 11-05-2008, 09:39 AM
DoubleSh0t's Avatar
I didn't even realize our cars had shock sensors... What do you have to do to set them off?
Old 11-05-2008, 09:48 AM
(Mid-Atlantic)
Our cars don't have a shock sensor
Old 11-05-2008, 09:59 AM
DoubleSh0t's Avatar
That's what I get for listening to a
Just kidding...
Old 11-07-2008, 12:57 AM
'99 2.3 CL
iansanderson's Avatar
When the siren goes off, is your dome light on?
Sometimes, the hood contacts can get dirty. Try cleaning the hood latch with some simple green, a brush and rinse it off. Then spray the assembly with some WD-40 and work the hood up and down a few times. See if that helps.
Old 04-22-2009, 03:19 AM
6th Gear
Wonseok's Avatar
Thank you. I had the same problem..My problem was hood latch..
Old 04-22-2009, 07:52 AM
Jonesi's Avatar
Far from a expert on the make and model but I know bad door actuators can also be a result of the alarm going off. Common problem in the second gen Legend 1991-1995.
eastcoastguy
10-29-2015 03:00 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Sue1910
2G CL Problems & Fixes
09-27-2015 12:34 PM
Quick Reply: Alarm goes off randomly
