aftermarket deck install
Old Aug 13, 2004 | 08:18 PM
Xenologics's Avatar
Peace out A-spec
has anyone installed an aftermark deck???
if so please let me know what i'll need, such as harness... etc
i have a mount. i was told it was hard because of the intergrated amp in the car
please help
Old Aug 13, 2004 | 08:25 PM
fsttyms1's Avatar
all you will need is a harness (from a accord) and the metra dash kit. when using the harness it bypasses the amp (nothing for you to do but plug in the new harness) the one down side is if you plan on using the factory speakers you will loose the rear sub, the accord doesnt have a sub and no one makes a wire kit for the tl
Old Aug 13, 2004 | 11:10 PM
Xenologics's Avatar
Peace out A-spec
is there anyway to keep the sub??
how great is the sub?
Old Aug 14, 2004 | 12:54 AM
pistacio's Avatar
Drivin' it till it dies!!
Will the voice be lost for the navigation also? (That might be a stupid question)
Old Aug 14, 2004 | 12:10 PM
Xenologics's Avatar
Peace out A-spec
anyone with info please help
Old Aug 14, 2004 | 05:38 PM
Xenologics's Avatar
Peace out A-spec
i also need help in how to take out the stock deck and if i will lose keyless entry too
Old Aug 14, 2004 | 07:15 PM
Hurleysurf24's Avatar
alpine i believe has two decks that will work with the touch controls on the steering wheel i believe .. last time i checked was like in 2000 on the acrura legend website .. so might not remember exactly.....
Old Aug 14, 2004 | 07:36 PM
NYZGREATST's Avatar
Sig Rho's Finest
y the hell would you lose keyless entry if you took out the stock deck?
im sorry to be rude. but the answer is no, you wont lose the keyless entry
you can keep the stock sub if you directly wire the stock sub directly to the H/U or something like that however, the stock sub sucks and its way to much of a hassle. just get a aftermarket amp and box, you will be alot better off.
Old Aug 17, 2004 | 11:24 PM
OKAY here we go ill go step by step a breif detail if you want e mail me WellChosen54@aol.com for anyone who want more info i installed a 7inch LCD dvd player screen in my car nice! #1 remove wood trim and undo the screws holding radio ....also u will see screws on the side holding the side panel to the center panel remove those....open ur center console remove the carpet piece u see 4 screes undo them and slide back...u will see a harness unplug... take out ur shift knob lefty loosy take out your plate and the whole pice take out the center pice between the seat heates prys itout using a flat head. after u took out the screws on the side behind the wood trim that hold that pice together u should be able to remove it ...what u do is pull our or push in to pull out the seat heaters u will see harness connecting each take out remember which goes where they are different colors to help u rememeber.. and take out that whole pice now open ur fuse box u see a screw undo it and remove..pull panel under steering wheel off...u need to unplug the harness that connect to cruise control as well.. when u remove the side panel ( where u knee hits when u drive) u will see a bracel holding the radio undo them....u remove the cd holder .....take out the whole piece and remove...afte ru unscrew them u should be able to see the radio falling (tilitng down) pull out and remove harness and antenna adapter from back) wire up the new harness basically color coded. and put the antenna in the new antenna adapter of radio ....foloow directons on intalling mountin kit. from metra. and put screws back on bada bing bada boom ur done more details e mail me ill also try to post pics
Old Aug 17, 2004 | 11:37 PM
NYZGREATST's Avatar
Sig Rho's Finest
that wsa a shit load of words
deyum noobs, you guys need to learn the SEARCH FUNCTION
http://www.abunchofcars.com/diy_page...er_console.htm
thats how u install a headunit.
Old Aug 18, 2004 | 07:48 AM
JnC's Avatar
JnC
Former Sponsor
Metra dude metra, search for metra dash kitz website on any search engine and you will find it. I believe this is an old topic now, and VERY OLD shall i say . But good luck you would need the kit which comes in black, paint it to match the interior color. You will lose the voice thingee with the navi, the steering mounted audio controls, and also the rear sub, good news thou is that u can use the Bose's crappy speakers, which i dont think are worth a dime.
Old Aug 18, 2004 | 05:00 PM
Xenologics's Avatar
Peace out A-spec
yeah i decided not to install my aftermarket deck
time to sell it off and buy an icebox
Old Aug 18, 2004 | 09:18 PM
pistacio's Avatar
What year Accord? Does it make a difference or are they all the same?
Old Aug 18, 2004 | 09:48 PM
fsttyms1's Avatar
get rid of the factory headunit, its the best decision you will make for audio. it will make the factory speakers sound better, and you wont have to worry about playing cd's.
as for what harness to use 99-01 accord
Old Aug 19, 2004 | 07:21 AM
Scott P's Avatar
Mobile Elec. Guru
[QUOTE=tpatel]y the hell would you lose keyless entry if you took out the stock deck?
[QUOTE]
I am imagining either he or his misguided, uninformed installer if thinking of the 96-98 honda civic, where the domelight, and keyless entry were tied in with the factory radio
TxRzrBk
Sep 17, 2015 01:07 PM
Silverstead1
Sep 17, 2015 06:45 AM
Dunnik
Sep 15, 2015 11:52 PM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
trinikidcl
Sep 4, 2015 12:56 AM
