adding amp and subwoofer
my tl is 2003 s-type and iterested in adding a little more bass to the acura/bose system. i might either buy an LOC or an amp with the line-level-input. where do i splice in the wires. if after the head unit, where exactly? and does this harm the bose system at all? nee help
thanks |
you might wanna get it proffesionally done. My friend from sound systems says doing TL's is a bitch
the DIY is on the stereo forum of this site. I've done this amp and 2 10" addition to the stock bose and it's not ez but doable.You can accually use a stand type low or high level input amp.
i did it too and you can do it, i guarantee. you will just have to remove the rear seat to access the wiring for the stereo.
there are wiring diagrams available here on the forum just try a search for "stereo wiring" or something like that. i tried splicing it between the EQ and the stock sub amp. my output is not very loud though so i suspect there is a voltage drop on the signal after the eq. i would recommend taking it between the head unit and the eq. all you'll need is an LOC and some 'tap-in' connectors from walmart or radioshack. let us know how it goes or if you need more help! SSTS |
sorry for double-posting. i outran my 5 minute limit for editing my post. ive ridden in a tsx once and i looked at one when i bought my tl about 2 months ago. nice cars for what they are, but just not on par with the tl-s.
someone else did comment though that since it shares the rsx engine that it may be alot easier to beef up than ours. oh well.... |
Convert your sub outs at the sub to RCA and run to your amp. Easiest thing to do.
Originally posted by RACINGHART03 Convert your sub outs at the sub to RCA and run to your amp. Easiest thing to do. SSTS |
whatap SSTS, its been a while. u think if i hook up an aftermarket amp to the stock sub, it would help a lil? i dont have the cash to do the full system makeover just yet.
Originally posted by Dark DJ whatap SSTS, its been a while. u think if i hook up an aftermarket amp to the stock sub, it would help a lil? i dont have the cash to do the full system makeover just yet. |
Originally posted by Dark DJ whatap SSTS, its been a while. u think if i hook up an aftermarket amp to the stock sub, it would help a lil? i dont have the cash to do the full system makeover just yet. it will definitely help you, but you have to be careful not to blow the stock sub obviously. im sure it can't handle much more than 150-200W peak (i would imagine its posted somewhere around here). if you plan on upgrading to a sub-box or to make your own box in the future then i would say go for it and grab an amp on sale from best-buy or circuit city. the only drawback is that you essentially will have to do a little custom wiring to bypass the stock amp. which would'nt be terribly hard, but you will most likely have to fashion a custom connector to go from the new amp to the stock sub. unless you cut the existing connector off and wire it up to the new amp, so long as you dont care about putting it back to the way it originally was. circuit city and best-buy usually have some good deals though for two 12" subs, box and amp. if you want a cost conscious solution i would go with that. but like i said if you plan on going big in the future, then sure, go ahead and buy the amp now and the sub later. hope this helps, sorry for the drawn out post. and by all means check out your other options like the basslink or a bazooka tube. you may be perfectly happy with just that. $350 for the basslink (the first site i found, you may find it cheaper) is a decent price. my alpine amp and box together cost about $550 if i recall. i don't regret spending it, but that may not be as much as you're willing to part with. SSTS |
SatinSilverTypS- thanks for the infor. but just want to make sure. if i spliced the wires before the amp for the stock sub, that should work right? is that signal already EQ'd. Do i still need LOC around here?
perfusion |
awesome SSTS, i think ill save up for now, i might get some hookups w/ some subs n and amp. but regardless ill keep your suggestions in mind!
