Add bluetooth to 04-05 TSX with aftermarket amp?
Professional Newbie
So about this time last year I did an overhaul of my stereo system. I added the "mercman cable," speakers, and an amp.
Now I'm interested in adding a parrot bluetooth system to the car and I have no idea how to do it with this aftermarket setup.
Does anybody with a similar setup have knowledge or experience adding an aftermarket bluetooth system?
Thanks!
Thanks!
you must install it after your amplifier. you really only have to interrupt the front speakers. use a relay and trigger the amp off while you make/receive calls.
Professional Newbie
So is this an entirely plug and play solution I can't tell if this cable takes care of the relays or if there is anything additional I will need to add.
http://www.aftermarketcellular.com/ic/QCHON-1.html
its hard to tell just from that pic. is there anything there dealing with a mute wire? what needs to happen basically is the remote turn on lead to your amp must be turned off while youre receiving a call/making a call/using the bluetooth thing at all so that the only audio from the bluetooth can be sent to the speakers. so the harness is good for interrupting the speaker wires and doing so neatly. can you post a link to the manual for the device maybe?
ok after looking at the harness again it looks like it goes behind the OEM radio. if you have an OEM amp it prolly wont work. if youre installing your own aftermarket amp, then you can just run your wires there and you should be fine.
Professional Newbie
I have an aftermarket amp in the trunk, and a rather complicated mute wire setup under the backseat. In the area near the factory head unit, I still have all of the factory connectors (speaker and radio harness) because I am using "mercman's cable" and a honda speaker wire harness. So if I have all of the factory connectors on an aftermarket setup, where does that leave me?
I can't find a manual for the bluetooth device or the harness so it's hard to tell what actually needs to happen. I don't want to buy the things and just have to return it and eat the forward and reverse shipping costs.
I feel like an idiot for not knowing what to do here because not only did I install the entire sound system myself last year but I'm an electrical engineer at an audio company
Professional Newbie
Hi Max,
Did you also use the Civic harness or the speaker connections or did you run your own wires to the speakers? That harness says it is for non-amplified systems but then it lists the TSX? Basically, the system has a relay to switch the front speakers to the BT when you get/make a call. I did not see a mute wire mentioned but it is a good idea to shut the amp off during the call. More info like a wiring diagram would be good.
Jeff
Jeff
Jeff,
Good to see you back on the boards.
Max,
You might want to check this harness out. It's what I'm currently using on my 05 TSX with the OEM audio system and Parrot MK6100. Its made for vehicles using an external amp, OEM and I'm assuming aftermarket as well.
http://www.safewireless.com/hands-fr...cura-p-14.html
Max,
Looking at this page (as an example):
http://www.safewireless.com/hands-fr...-kit-p-10.html
The package includes:
1 radio mute cable with line output (ISO cable)
This is where the BALUN comes in handy....
You could then use something like this:
http://www.smarthome.com/97252728/LL...TL02001/p.aspx
![](http://cache3.smarthome.com/images/97252728big.jpg)
To switch the audio signal on the front speakers, and use the mute signal to cut out the signal to the rear speakers. If your going to use a relays to do this, you might want to put a 100k-1M resistor in the signal path, and wire a relay that is normally closed (NC) in parallel with it. This would significantly attenuate the signal rather than turning it off completely, but would probably avoid loud pops when it clicks on/off.
That would have to go between the BALUN and the amp. If you had an amp that already had balanced in this would not be so easy.
Professional Newbie
Hi Max,
Jeff
Jeff
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
Here is the only info I can get from the site. Sorry about the PDF form, I'm at work and can't get a decent screen cap:
http://www.parrot.com/documents/en/s...ad12_ad112.pdf
http://www.parrot.com/documents/parr...ide_zone_c.pdf
(page 5 specifically)
Professional Newbie
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I definitely like the idea of attenuating the signal to avoid the pops!
Professional Newbie
Jeff,
Max,
Max,
those harnesses are worth the money. all the parrot kits ive installed have been without them and it SUCKS. looks like crap when you want to remove the unit too.
Professional Newbie
So what's the verdict? Is this harness and the parrot unit all that I need?
- John
Professional Newbie
Thanks for the info guys. So now it's time for a couple noob questions...
1) Does the radio need to be on for the call to come through, and does it need to be on a particular input
2) Can I do all of the wiring up front or am I going to need to tear apart the back again?
3) Will this harness take care of muting the amp, or do I still need a solution for that?
4) I have the SNHOND3 aux-in on my CD-C port, does that matter?
Former Sponsor
All the wiring will be done right behind the deck.
The Parrot mutes the signal when a call comes in.
The Parrot and Y harness are only using the main power/speaker harness and will not affect your CD changer port.
Pegon95
09-15-2015 01:54 PM
ivegotthenav
09-11-2015 07:51 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
trinikidcl
09-04-2015 12:56 AM
