'99 CL 3.0 Rear deck rattling with trunk bass
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
I have $3,800 sound system in my car and is comp. potential for clarity, however all purpose is being defeated by my rear deck that rattles with high freq. bass. Can anyone suggest what I can do to fix this. My fiancee has a '99 Honda Accord. Almost same car. Similar sound setup in her trunk and she has no rattling at all. Can anyone please help.
Thanks!!!
AR
Thanks!!!
AR
OK few things to clear up........
our CLs are based off of and essentially the same as the 94-97 Accords of the 5th generation, a 99 is a 6th gen, youve got the 6th gen V6 in a 5th gen body
ANYWAYS, my 97 2.2 does the same thing under bass, but only when I have it WAY up, to the point where I worry about my ears over the vibrations, I had a temp fix I duno how I did it but I think it has something to do with the 6x9s in the back, if you can maybe try filtering real bass frequensies to them it should be OK, I have the rear deck of mine set to a 18dB/oct HPF at around 100 or so Hz...... and besides that another thing is that my Kappas touch a tie bar thing in the trunk space and that might do something as well, im only running a 400W 10" system for now, but in a day or two itll be swapped out with a 500W LAT system..........
and another thing is I had alot of vibration noise from the inside, I dynamatted my rear plate, and it stopped, as for physical vibrations, thats gonna happen regardless
3GTLOwns
09-09-2015 09:51 PM
