6 DISC Player will not play burned CDs
Old Jul 5, 2004 | 11:58 PM
snappy's Avatar
I used to own an '02 TLS that would play burned cds. My new TSX does not. Is there a new security standard for new cd players that identifies copied cds and ejects them automatically? anyone else having the same problem?
any info would be appreciated before i take this car back to the dealership and ask them what's going on.
thanks in advance.
Old Jul 6, 2004 | 12:06 AM
Dan Martin's Avatar
Photography Nerd
Never had a problem with mine. Have you tried a different brand of cds?
Old Jul 6, 2004 | 12:19 AM
elduderino's Avatar
VP Electricity
No, there is no "security standard". Never ascribe to malice what can be explained by incompetence.
Try CD's burned on another machine.
(PS: Didn't mean YOUR incompetence, but the manufacturers... sorry about the lack of clarity.)
Old Jul 6, 2004 | 12:21 AM
fdl's Avatar
fdl
I've never had a problem playing cd-r's in my TSX. I dont think rw's will work though.
Old Jul 6, 2004 | 12:23 AM
NeoChaser's Avatar
UK Spec
i think ti's the burner..
Old Jul 6, 2004 | 03:11 AM
jginnane's Avatar
! deadmau5 !
[QUOTE=snappy]I used to own an '02 TLS that would play burned cds. My new TSX does not. [QUOTE]
1. Try to avoid "silver/silver" discs (often the cheapest). The laser burns thru the clear plastic on the underside OK, but a s/s disk doesn't have any protection for the one metallic layer. Slightly above the cheapest are Taiyo Yuden, etc., which almost always have a matte or opaque finish surface adhering to the silver on the top.
2. When you burn an audio CD-R in a program like Nero, crank down the burn speed. So if your burner's capable of 52x, then 16x is the max you should be using. If you're getting more than 1 in 20 coasters, then reduce burning speed even more.
Old Jul 6, 2004 | 07:24 AM
asulak01's Avatar
TechLedr
No Problem here - Even works on RW's
No problem here. All my computer burned CDs worked. I even discovered (to my Joy!) that it plays CD's burned using RW media, which will save me a bunch of CDs now. I can burn MP3's to CD, then erase and reuse, since I didn't get the MP3 option (had to have Cassette ;})
You might want to ensure your CD's a "Session Closed". Some players can't handle open session.
Also, because of noise issues, I never burn above 12X.
Old Jul 6, 2004 | 02:52 PM
x911gt2's Avatar
Also, cd players can only read the 1st session on a burnt disc. Subsequent sessions cannot be read.
Old Jul 6, 2004 | 03:10 PM
slobeatz's Avatar
Littering and.....
I haven't had any problems with my CD player not playing burned CD's. I stick with Imation and Sony blank CD's because I've never had any problems with them on any CD player (even my old 11 year old stereo) Also, I max out my burn speed at 21X
Old Jul 6, 2004 | 03:17 PM
jlukja's Avatar
I've played a lot of burned CDs in mine without problem. As was suggested above, try burning at a slower speed (16x) and try using a different brand of cd-r. I used Memorex before and now use TDK and all my burned CDs work flawlessly.
Old Jul 6, 2004 | 03:26 PM
dzuy's Avatar
Troutslap Mod-DUH-rator
almost all of my cd's are burned. no problem whatsoever
maybe try cleaning your player with a lens cleaner? or a different type of cdr? i use imation
Old Jul 6, 2004 | 03:54 PM
Zigen's Avatar
all my cd-rs play fine...try a cd-r that is burned by some other burner before you go to the dealership...
Old Jul 11, 2004 | 05:25 PM
Arcticcl9's Avatar
Can't wait to drive
Suggestions..get another burner and/or media (read: not cheap / no brand). Some of them here are same as above, but they are important
Reduce speed to no more than 16x. Music CDs has a primitive form of error correction compared to data discs...comparing a "My data CDs are fine at 52x" to "My tsx won't read my 52x burnt music CD" is like comparing apples to oranges. There are exceptions to this rule (some burners/media combination yeild good results even at higher speeds), but try that before investing on new media/hardware
and oh..there is no such thing as a multi-session music CD
Old Jul 11, 2004 | 05:51 PM
IndyTSX04's Avatar
sometimes CD-RW's don't play, but CD-R's do. This happened on my 2000 civic. also, of course make sure the files on your cd are in .cda format and not some other format like .wma or still in .mp3 format
Old Jul 19, 2004 | 04:10 PM
doinoyou79's Avatar
Pharm.D. Man
you hafta burn the cd's as one session. there should be an option for this on the cd burning software. multiple session cd's will not play on cd players.
Old Jul 19, 2004 | 04:43 PM
jcg878's Avatar
Obnoxious Philadelphian
I have had a problem with this recently as well. I seem to have fixed it by recording in "track-by-track" mode all at once rather than "disk-at-once". Don't know why, and I'm not sure it's a permanent fix since it's a different burner than I used to use.
SidhuSaaB
May 30, 2020 12:40 AM
calrow
May 3, 2017 10:21 PM
Fool
Mar 10, 2016 08:42 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
hashbrown
Sep 29, 2015 12:13 PM
