TL: 6.5" speaker screw question (using 3/4MDF + stock bracket)
K-Fed's Stunt Double
hi guys,
so i managed to properly cut the speaker basket/bracket from the stock bose speakers, and i have a question about how to secure the speaker+basket+spacer into the door.
first, here is a pic as i await my 3/4 MDF spacer:
![6.5" speaker screw question (using 3/4MDF + stock bracket)-8xnlwdd.jpg](https://acurazine.com/forums/attachments/audio-video-electronics-navigation-22/100536d1683150651t-6-5-speaker-screw-question-using-3-4mdf-stock-bracket-8xnlwdd.jpg)
![6.5" speaker screw question (using 3/4MDF + stock bracket)-zielakh.jpg](https://acurazine.com/forums/attachments/audio-video-electronics-navigation-22/100537d1683150651t-6-5-speaker-screw-question-using-3-4mdf-stock-bracket-zielakh.jpg)
any help on this matter would be greatly appreciated. i'm happy that i managed to get the baskets to fit, and with the MDF spacer it seems to be perfect. the last concern is properly screwing the speakers to the spacer/basket/door.
thx
- is the stock 4x30 screw long enough to go through the MDF spacer+basket and into the door?
- if not, can you guys please recommend the screws that are of sufficient length such that they can go through the spacer/basket and into the stock holes?
- surely if the stock 4x30 screws aren't long enough to go through the spacer+basket+door, then i need two types of screws (??):
- one type to secure the speaker into the MDF,
- another type to secure the MDF through the speaker basket screw holes/spots and into the stock 3 holes
- for one of my speaker baskets/adapters, the screw holes are sort of gone. while i can easily get another bracket and cut them again, this doesn't seem to be a problem since the speaker/mdf is "above" the basket holes and thus the main priority is to ensure there is a "clear path" to the stock screw holes on the door (which is the case)
- please correct me if this is wrong.
- i read the original howto thread here: https://acurazine.com/forums/audio-v...eakers-286546/ but i don't think that's exactly the issue here?
- he is just suggesting that the bore of the spacer holes that guide the speaker/MDF into the door should be slightly larger than the diameter of the screws used to secure them in the hole, right?
thx
i don't think this thread will get enough eyeballs for an answer in this forum. is it possible a mod could please move this to the appropriate forum where it could get a little more traffic? mb 2g generic forum?
thanks.
thanks.
