6.5 Component Recommedation for TSX
05 Carbon Grey
I'm so confused i don't know what to get. I currently have a JL 300/4 amp and I'm trying to find speakers that will match them. I have a 6 yeaor old set of Oz audio 130 cs (5.25) components but I'm not sure if they will fit in the stock location.
I listen mostly to R&B, Top 40 and Dance and was wondering if anyone had any suggestions. I'm going to set my budget from 200-300.
Should I keep the Oz audio (and hope they fit)
Here are the stats:
Oz 130 (MidBass)
Diameter 5.25"
Impedence 4 ohm
Voice Coil Diameter 1" (25mm)
Magnet Weight 16oz
dB/SPL 1W/1M 91dB
Fs 93 Hz
Qms 4.321
Qes 0.920
Qts 0.759
Freq. Response 60 - 5000Hz
VAS 040 M3/.141 ft3
RMS/Peak Power 80/150 Watts
Other components I was considering were Boston Pro Series 6.5 pr Pro 60 and
Focal 165v2 Polyglass.
5.25 or 6.5......
Any help would be appreciated!
Here are the stats:
Oz 130 (MidBass)
Diameter 5.25"
Impedence 4 ohm
Magnet Weight 16oz
dB/SPL 1W/1M 91dB
Fs 93 Hz
Qms 4.321
Qes 0.920
Qts 0.759
VAS 040 M3/.141 ft3
5.25 or 6.5......
5.25s won't fit, unless you can find a bracket to adapt it for you. It could be that you could find a 5.25 -> 6.5 bracket, and use those in conjunction with Metra brackets for Honda. That would allow you to easily use your existing 5.25s, but that's like $40 of brackets alone. IMO spend the money on new, better speakers.
I like the infinity's so much that I just put them in my car. Brand is all preference though, go to your best local car audio place (not best buy) and take a test listen to some speakers.
mlody
12-04-2019 02:11 PM
polish_pat
09-25-2015 12:24 PM
