2002 TLS Speaker Sizes
Old Dec 17, 2002 | 09:06 AM
2002TLSNavi's Avatar
Can someone please tell me the size and mounting depth for the front and rear door speakers, for a 2002?
I did a quick search, and saw a several differenct answers. I was going to order some Infinity Kappas. Has anyone successfuly installed these without any major door modifications? (besides making a spacer or something -- I'd like to be able to go back to stock if ever necessary)
Thanks in advance,
Dave
Old Dec 17, 2002 | 06:45 PM
Darkshear's Avatar
l33t
I just installed Boston Pro Z6's in my TL,
both front and rear doors are 6 1/2", both can use a 3/4 inch spacer, 1 inch if you REALLY need it, but its not recommended...
Old Dec 18, 2002 | 01:05 AM
You have a max depth of 2-1/2 inches that can protrude inside of the door frame. You hit the window at around 2-3/4 inches. Then you have a max of a 1 inch spacer before you have to go to extra lengths to get the door panel to snap back on. The stock spacer/basket is 3/4inches thick. What tends to really get you is the small door hole cutout... it is only like 4-1/4 or 4-1/2 inches wide. So if you have a speaker with a wide cone basket it hits the door frame. Some people have gone as far as adding 1-1/2 inch spacers, but they also replaced the door panel snaps with longer ones.... and I would still think that the panel would bulge out a bit?
Those are your limitations... I do believe that I have heard of several users installing Kappas by making a 1 inch custom spacer.
Good luck!
Southbound
Old Dec 18, 2002 | 01:21 AM
As a reminder, while the Kappas sound good in the store, they will sound EXTREMELY bright with their titanium tweeters in the Acura/Blose system with its hideous EQ.
I sampled them in my car at one point. So I'd plan to bypass the EQ and add an amp if you buy them.... It's a bummer, but Acura/Blose didn't make it easy for any simple upgrades...
again, Good Luck!
Southbound
Old Dec 18, 2002 | 07:47 AM
Thanks Southbound,
I was planning on bypassing the EQ eventually. Figured I'd give it a try with the eq in first, before I tear apart the center console though. See how far turning the treble down gets me. I settled on the Kappa's because I got an incredible deal on them through a friend. Also the swiveling tweeter should help a bit with imaging. I personally hate door speakers, but I don't have the time to build, nor do I want to spend the money to have someone else build custom kickpanels.
Eventually I'll probably add a 4 channel amp, I just don't have it in me to spend hours out in the cold running wiring for it, it's been in the mid 30's in Jersey lately.
Dave
kb1rl
Sep 30, 2015 10:17 AM
Tribalheads
Sep 29, 2015 03:24 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
polish_pat
Sep 25, 2015 12:24 PM
