'06 Navi Vocie Commands
I just completed a Non Navi to Navi install on my ’06 TSX. I posted to the A/V section. Thread is called Non Navi to Navi – It can be done!
While everything looks great, I was unable to get the Voice Command feature to work. I’m assuming it’s got something to do with the fact that the ’06 TSX came out with Hands Free Link and ’05 did not have this function.
This is what I tried but was not successful:
I ran the Gray (STRG SW), Lt Blue (MIC SH), Pink (MIC GND), AND Blue (MIC SIG (+)) from the NAVI DVD unit to:
The HFL Control Unit in the passenger sidekick panel pin #2, #20, #22, and #21, respectively.
Unfortunately, this attempt did not work.
The ’06 tuner came with two additional connectors for HFL that since I have ’05 NAVI head unit I’m not using. This may be one of my problems.
I’ve attached connector diagrams for the HFL control unit, and two Steering Wheel Connectors for your reference.
[img=http://img79.imageshack.us/img79/6721/hflconnectorno7.th.png]
[img=http://img79.imageshack.us/img79/9979/connectorbeb4.th.png]
[img=http://img372.imageshack.us/img372/4152/connectorcjl1.th.png]
I would really like to get Voice Command to work and would appreciate any help.
Thanks.
Thanks.
Thanks.
Thanks.
Sorry, you're pretty much in un-charted waters here. I know you've got the ETM and service manual already, and I'm afraid there's more info in there than any of us could provide alone.
I imagine if you came across an 06 navi unit, you could do that swap, as you've already done all the hard work. The 06 does come with additional wiring though, I found that out the hard way when I started cutting into my stock harnesses with an 04 ETM. Before I realized it, I had cut about 6 wires, then realized my harness had 24 pins where the previous one had 20, and things were different. This was right when the 06s came out and there wasn't good info on these things.
Thanks for the response. I'm not giving up on this one just yet. I may even try to bypass the whole HFL control unit and make my own switch. This will take some studying of the ETM, though.
I've seen a lot of your posts. Really good stuff. Thanks for sharing with the group. Let me know if you ever need any info out of the '06 ETM. Just PM me.
Also, I'll let you know how this little project goes. There has to be a way around it!
Never give up, never surrender. I've got an 06 ETM now too, so tackling projects like the converter-less backup cam are on my springtime list of to-do's.
Never give up, never surrender. I've got an 06 ETM now too, so tackling projects like the converter-less backup cam are on my springtime list of to-do's. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Sounds like a big headache.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
