TL: 03 TL Temperature readings
Always Working In
No there is a way to adjust the temperature. I think its - turn ignition to on but not start. Press select and reset and hold it for like three to five seconds. The temperature range will adjust from -10 to +10 adjustment factors but by three's I think. Kinda wierd but play with it till you get it right.
There is a way to test the sensor by placing in icewater and checking resistance.
You can Only change the Offset by +3 or -3 (°F) (°C in Canada)
If you are getting a strong offset you can move your temp sensor (Located in Front of Condenser) lower than where it is, To make sure all air is hitting it.
Thats my 2c.
Thats my 2c.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
