'03 TL-S and CDT Audio
I'm gonig to be recieving a CDT Audio CL-61 component set for the front speakers and CDT AUdio CL-6x for the rear doors. I would like to know if anyone has these and if they had to cut the door in order for the speaker to fit or if they need a spacer and if so how big was it? Any help would eb greatly appreciated.
Also, I have the Kenwood DDX-7015 headunit... would it be ok to power those speakers from the headunit? I realize that with an amp they will sound MUCH better... but thats to come in the future. Thanks.
BUMP
I just got the speakers so i need this info asap. I dont want to take my car to a shop, because everytime i go to do somethign to my car i find something they fucked up and tried to cover up... so i would like to do this myself.
the stock speakers had about a 6 inch hole cut, but it was oval shaped, so if those are 6.5 inch speakers, you will have to cut the door some. Its easy though, only takes some tin snips to get it done. As far as the spacer goes Im not for sure, but you can put as big as a 1 inch one and the door panel will fit back on. Just make a ring out of some wood, put some dynamat around and behind the speaker to get the best sound.
You can power them with your HU, but that is really not a good way to go. Components need more power, I have fried many tweeters with 50 watts/speaker RMS. You will only be pushing 20 or so watts/speaker. So just make sure you dont blast them, because when you do, you will be giving the tweeters lots of distortion and you will fry them. So when you get an amp, get 75 or 100watts/speaker, then you can blast away when you want to and not worry about bad power.
Originally Posted by brianlin87
yeh i guess you can power them from ur amp, but you won't be happy by any definition
It will sound better than the stock unit, but it would be easier to run all the wires to your 5 channel amp from the beginning and not even use your new HU to power your speakers at all.
the amp im going to get is the memphis belle 16-mc1300d. it has 1 channel for the sub at 1100 watts and 4 channels for the speakers at 75watts each.
cool. thanks a lot for hte info fellas.
yea, i got a really ogod price... thank god. BUT, one of the tweeters had a small dent on the cover that i TRIED to fix
a new one is gonna cost me $25
i had cdt 3-ways in my 1st gen. you wanna amp em. its bad to under power speakers...especially considering they probably require around 50 watts or more rms and youre gonna be giving them around 14......
MetalGearTypeS
Aug 29, 2016 08:28 PM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
