00 TL headrest TV questions/problems
Old Feb 27, 2006 | 12:10 AM
NYZGREATST's Avatar
Sig Rho's Finest
today i bought 2 farenheit screens and tried to install. for some reason i cant get them to power up. i used a volt meter and im not getting power to either the screens or the video amp. the way i had it wired was this. from the power wire behind the headunit, i sliced to the power on the monitors. from the ground wire behind the headunit i had it spliced to ground on the monitors. without the monitors, the two wires behind the headunit give me 13V on the reader, once i connect the monitors i get 3V. since, the wires off the screen are short i connected the headunit wires and the screen wires with speaker wire. im thinking i have a ground issue. i checked the volts at the end of the speaker wire before connecting to the screen and i get 3V, which makes no sense. any thoughts?!
i know this may have been difficult to follow so here is a diagram
thick red and black wire is the speaker wire i used to connect the screen. the blue circle is where i get 13V and the green circle i get 3V.
Old Feb 27, 2006 | 02:17 AM
boku's Avatar
Scru U guyz, Im Goin Home
First bench test the screens cuz when ur diagnosing a problem it sucks to find out that ur dealing with DOA product after the fact.
Then:
- Test the ground
- Check the fuse
- Try running a fused power straight from the batt
- Try a relay
Old Feb 27, 2006 | 08:30 AM
Jonesi's Avatar
120%.. Been there done that.. I bench test everything now before installing..
Old Feb 27, 2006 | 12:18 PM
NYZGREATST's Avatar
Sig Rho's Finest
by bench test you mean to run it str8 off the battery right?! i have done that and it all works fine. i figured out why i was getting the 3V after the extension. before i connect to the screen i get the normal 13-14V but as soon as i connect it to the screens i get 3-4V. i have no idea what the hell is going on. any thoughts on that?
Old Feb 27, 2006 | 04:30 PM
NYZGREATST's Avatar
Sig Rho's Finest
done. got it all figured out and everything works perfectly. the screens look great. the problem was i was tapping power from the wrong place behind the headunit. i was tapping it after it was connected to the headunit wires instead of right where the metra kit begins. once i connected it there and found a solid ground point everythin worked. thanks for the help guys. if needed
Old Feb 27, 2006 | 04:35 PM
dark inspire's Avatar
El Presidente
come on Tarpan, u know better than that! hahahaha
Old Feb 27, 2006 | 11:00 PM
NYZGREATST's Avatar
Sig Rho's Finest
YEA YEA YEA!!!!! ill get sum pics up tmw. i did realize that one tv is lower than the other, its not a huge issue but its def gonna eat me up inside. i may just buy a new headrest or just the leather cover or somthing. we shall see
Old Feb 28, 2006 | 12:31 AM
Blazin_TL's Avatar
Registered User
whered you get em? and 4 how much?
Old Feb 28, 2006 | 01:40 AM
NYZGREATST's Avatar
Sig Rho's Finest
i got em from philly, stupid impulse buy. it was 475 with the video amp (yea i know, kinda pricey) but they are the farenheit t-6501's - great resolution, its better than my avic-d1.
OT: yo were u on my ass the other day on richmond rd?! tl looked exactly like urs.
Old Feb 28, 2006 | 03:01 PM
Blazin_TL's Avatar
Registered User
nah wasn't me... i woulda honked lol
Old Feb 28, 2006 | 07:53 PM
Scott P's Avatar
Mobile Elec. Guru
simple fix. the power behind the radio isn't going to be enough current to turn on the screens and the amp. you are going to need a seperate power source for the video. I would suggest tapping the ignition harness.
Old Feb 28, 2006 | 10:51 PM
Hova1222's Avatar
hey i was thinking about buying those. Now that you have then I probably will. Is the resolution really that good?
Old Mar 2, 2006 | 12:44 PM
NYZGREATST's Avatar
Sig Rho's Finest
yea man they are great. i literally connected them and held one up against my avic-d1 and saw a better picture in the farenheits. they def are good quality screens.
Yea thats whatthe problem was. i basically tapped the power farther back into the headunit area and that seems to work perfectly
yea i figured that much! i was like what the hell is he doin back there. man was bein such a dick behind me. he was tryna overtake my ass but that side of richmond is single lane! i was like relaxxxxxxxxxxxxxxx
Old Mar 3, 2006 | 05:34 PM
NYZGREATST's Avatar
Sig Rho's Finest
here are a few pics. the wrinkle in the leather really bothers me. its a simple fix, just gotta take them out and loosen the leather in the headrest mount. will get to it this weekend. thanks for all the answers guys
Old Mar 3, 2006 | 08:18 PM
El Presidente
damn! screens are cool! lol
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
ovcegon
Sep 22, 2015 01:17 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
kareshi
Sep 3, 2015 03:38 PM
GOTHAM818
Aug 6, 2003 09:36 AM
