Wiring diagram of Navi Buttons
"Advance"
Hi guys, I was wondering if one of you have the wiring diagram of the Navi buttons. Can't seems to find this in the Servie Manual....
Here's the buttons I want to reroute:
Thanks guys!
Thanks guys!
"Advance"
KN_TL always there to help out ahah thanks bro
Let me know if this could work:
Connect the buttons on the display, check the voltage of each wire to get the POWER wire. Then push on one button and get the voltage of each wire to see which one react to the "Push".... ???
I've got it apart. Just need to map it out.
If you have an ohm meter, you can just use it. But I should be able to get you something soon. Just looking at it, it's just a set of switches with one side tied to a common pin, two are rockers and a 4-way where the joystick is.
"Advance"
Looks like your electrical Skills are higher then mine
Let me know when you'll get something I'll have to route those wire on a hacked USB Controller and then convert the controller commands into AppleScripts
THANKS AGAIN BRO!
THANKS AGAIN BRO!
Trying to confirm that the rear defog switch is momentary. The D7 and D11 wires from that bundle should show continuity when the switch is pressed and held and no continuity when released.
I'm going to wiring an aux trigger from my Viper remote start to the D7 wire to trigger the rear defog remotely. I assume the trigger needs to be pulsed (momentary) rather than latched.
I'll be pulling the unit later today and can check it then, but I thought I'd ask since you already have one apart. No big deal if you don't have the time.
ok VmtSquad, here is what I see so far. I was wrong about the center stick, it's a joystick and I am thinking it might be resistive. It has 9 pins and is so small, I can't really get any good readings from it. But the switches are:
Looking from the front, I have them numbered left to right
1, 2 ,3up, 4down, 5up,6down, 7,8
Looking at the back, again left to right, pins 1-11
Pin 1 - Switch 6.8
Pin 4 - Switch 5,7
Pin 7 - Switch 1,4
Pin 8 - Switch 1,2,5,6
Pin 9 - Switch 3,4,7,8
I hope this helps!
Pin 1 - Switch 6.8
Pin 4 - Switch 5,7
Pin 7 - Switch 1,4
I hope this helps!
Just took it apart and they're all momentary
"Advance"
Ok, so it'll be hard to tape on the center stick if I understand....
Isnt a way to simply reroute the wiring behind the buttons ??
If not I'll have to get this thing a part and look at it closely with you indications
THANKS BRO! Will keep u in touch
What is it you'd like to use the joystick for? Actually moving around on the screen? If so, then I can see what I can figure out. But if that is the case, you'll need the 2nd half that converts it to a computer compatible device. Definitely possible.
"Advance"
Pin 1 - Switch 6.8
Pin 4 - Switch 5,7
Pin 7 - Switch 1,4
I hope this helps!
So If I understand what you saying, if I press MAP/GUIDE I need to connect PIN 7 and 8 so that it sends a signal to my USB controller??
Also, which wire is the POWER, there must be a + and - to power the LEDS and be able to send signal with the buttons?? I would have to give the right voltage to those wire so I can use the buttons...right ??
I don't know if you noticed but this is my first time attempting this...I read the Keyboard hack on the net, but my electrical knowledge is limited ....
Have either one of you guys removed the upper vent panel to get to the upper bolts for the Display Panel Control Unit? How did you do it? I'm having a heck of a time and am afraid to pull too hard. I don't have the special tool but made one myself. I can get it hooked inside the vent, but I've pulled pretty hard and got nothing. I'm afraid to pull much harder.
Any tips?
Any tips?
Could it be possible to link those Pins to the right wire color??
The bulb pins are 10 and 11.
The colors are:
1 - light blue
2 - brown
3 - red
4 - dark blue
5 - black
6 - grey
7 - yellow
8 - pink
9 - dark green
10 - tan
11 - light green
Any tips?
Any tips?
http://www.desktopaviator.com/Produc...2040/index.htm
"Advance"
As for the bulb (LED) Pins 10 & 11, what voltage is needed to make them light?
I may use the little board you showed me, but i'll have to check the compatibility with Mac, since I'm using a MacMini in my car.
Ok so those buttons simply work as regular push buttons, this simply things a little. I simply need to find the right board for my application.
THANKS AGAIN BRO!
AnyNews on the center joystick?
THANKS AGAIN BRO!
"Advance"
THANKS AGAIN BRO!
THANKS AGAIN BRO!
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Haven't had a chance to look at the joystick yet, but looking at some parts places, it appears they are resistive.
http://www.ultimarc.com/minipac.html
Gotta stop dude, you are making more work for me
"Advance"
Here's the diagram from a OEM parts place. It's 8V and I think they are just plain incandescent.
Gotta stop dude, you are making more work for me !
"Advance"
But if you look at the buttons, the first two are just push buttons, the next two are rockers and the last two are again just push buttons.
So there are only 6 switch plates but two rock back and forth adding two switch points.
"Advance"
Alright I get it now lol....
Wire Colors (from left to right)
1 - light blue
2 - brown
3 - red
4 - dark blue
5 - black
6 - grey
7 - yellow
8 - pink
9 - dark green
10 - tan
11 - light green
So here it is just to keep kind of a work log ...
1- MAP/Guide = Wire 7-8 ; yellow-pink
2- Menu = wire 8 - ? ; Pink - ?
3- Setup = 9 - ? ; Black - ?
4- Info = Wire 7-9 ; yellow-Black
5- Zoom(up) = wire 4-8 ; dark blue-pink
6- Zoom(down) = wire 1-8 ; Light blue-pink
7- Cancel = wire 4-9 ; dark blue-Black
8- Audio = wire 1-9 ; light blue-Black
Is it me or I'm missing one wire for buttons 2 & 3 ???
Let me know if I'm on the right track cause when this will be done I'll go ahead and buy the Interface board
THANKS AGAIN FOR YOUR TIME BRO!
1 - light blue
2 - brown
3 - red
4 - dark blue
5 - black
6 - grey
7 - yellow
8 - pink
9 - dark green
10 - tan
11 - light green
"Advance"
I'm not sure how you are referenced the button numbers.
I haven't forgotten about the joystick. Other things getting in the way (fix a small leak in the house heating, re-cover chairs for wife, etc, etc.) I also just dropped a bunch of coin to do brakes, timing belt and water pump on my Pilot so that's on the list too. The weather up here (as you know) is still pretty mild for this time of year.
I'll let you know as soon as I can get to it.
"Advance"
No worries bro, I'll soon receive my Interface Board, will post my progress along the way, THANKS FOR ALL THE HELP!
We had the first snow on the ground last night, didnt even change my tires yet lol. It's now obligatory to have some winter tire in the Quebec province since last year. Will have to put a priority on this, still have till December 15th to install them.
Thanks again!
Thanks again!
"Advance"
Finally got time and $ to order the controller.
It will arrive to my door soon and will have the chance to test my NaviButtons ReRoute project.
Had any chance with the JoyStick bro?
Thanks!
Thanks!
Way I did was, I purchased USB gamepad(Play station style has analog and digital combind model) and soldered it to the factory navi button and use joypad to assign key emulation.
Tricky part is that joystick on the factory button is not left, right, up and down(look a like rotary type of joystick) and pins are so tiny.
I cannot remember exactly but I belived there is 10 or 11 pin soldered to PCb.
So, I gave up to find the pin and used it only for enter or select key for the keyboard emulation.
Please, let me know if you found better way.
The joystick and board are still sitting here unassembled.
I've been burning both ends of the candle with work and I'm also working on getting my garage insulated and heated. The mild weather is gone!!!!
I have some vacation coming up so I'll let you know soon.
"Advance"
Thanks KN_TL for you help, I'll have some Wiring question about the interface Board I purchased, seems like I'm missing some basic info.... will post questions here!
THANKS AGAIN!
THANKS AGAIN!
"Advance"
So here's my wiring question....
I now have this device in hand http://www.ultimarc.com/minipac.html
Here's the diagram:
I wanted to know how should I connect for instance one of my buttons?
Since 1 wire goes for couple of bouttons on the Navi Buttons I planed to use a small circuit board to easily connects all switches.
For instance " MAP/Guide = Wire 7-8 ; yellow-pink " how should I connect both yellow and pink on the interface board???
I admit that the interface board isnt really clear for my knowledge and if someone could give me a hand I would appreciate.
Thanks!
Here's the diagram:
Thanks!
I just remapped the navigation buttons for my carpc project and I figured out the wires for up/down/left/right on the stick.
Hope this helps.
Pin 1 light blue - Switch 6,8,D,L
Pin 2 brown - NONE
Pin 3 red - NONE
Pin 4 dark blue - Switch 5,7,U,L
Pin 5 black - Switch 2,3,R,U
Pin 6 grey - NONE
Pin 7 yellow - Switch 1,4,R,D
Pin 8 pink - Switch 1,2,5,6
Pin 9 dark green - Switch 3,4,7,8
1- MAP/Guide = Wire 7-8 | yellow / pink
2- Menu = wire 8 - 5 | pink / black
3- Setup = 9 - 5 | dark green / black
4- Info = Wire 7-9 | yellow / dark green
5- Zoom(up) = wire 4-8 | dark blue / pink
6- Zoom(down) = wire 1-8 | light blue / pink
7- Cancel = wire 4-9 | dark blue / dark green
8- Audio = wire 1-9 | light blue / dark green
9- Stick Up = wire 4-5 | dark blue / black
10- Stick Down = wire 1-7 | light blue / yellow
11- Stick Left = wire 1-4 | light blue / dark blue
12- Stick Right = wire 5-7 | black / yellow
Hope this helps.
Pin 2 brown - NONE
Pin 3 red - NONE
Pin 6 grey - NONE
I looked at this more closely and I think you'll need two interfaces. If you look at the common pins, they are 8 and 9 across all the non-joystick pins.
With the mini-pac, there is only one common point for all of those switchpoints on the interface.
You need something that allows at least two common points or have two points for each switch being detected. If you tie 8 and 9 together, you cut the number of switches detected in half.
The thing I haven't seen is if you can have two interfaces interacting with their code.
Are you using their code or doing your own?
