subwoofer location in 2013 zdx
What can be done to eliminate the rattling sound from the subwoofer? It was great for 4 years. Now with the volume around 23, it sounds horrible. It's not the subwoofer itself but more like what it's housed in.
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
I assume the subwoofer is located in the same place as in the 2010 ZDX. It's located under the rear cargo area behind the right rear seat.
It's located beside the tool case (under rear cargo area on left). Did you try to store anything in that area? Perhaps the rattling is caused by a loose tool?
Hope this helps
Cheers
Zdx subwoofer rattle
does anyone know what the procedure is to remove the subwoofer?
I just wanna pull it out and tighten everything up and add padding if necessary
Hello Kirkg811,
Hope this helps
Cheers
Hope this helps
Cheers
PgLgGrg
11-30-2022 10:24 PM
