Anyone have pictures of ZDX with aftermarket hitches?
Hello, anyone install hitches from Hidden Hitch or Curt on their ZDX? I can't decide which one to go with. I want to attach a bike rack, possibly ski rack in the winter. I really don't like how far out the OEM hitch sticks out from the bumber or else I'd go with that one because I do like the harness adapter. I'm looking for one that doesn't look too obtrusive, hopefully tucked right beneath the bumper. I'm also interested in how they affect access to spare tire. Thanks,
Cheers!
Cheers!
We had the OEM installed and the use the Dura Softride Bike rack, the distance that it sticks out, facilitates being able to move the rack away from the tailgate without taking the bikes off... it already has such a limited towing capacity, if the hitch was closer to the car the towing capacity would be even less.
TitusR (10-06-2011)
Cheers
I think the OEM is 1.5". I love the Dura Softride. We carry 2 or 3 but it will carry 4 and it does let you tilt the rack with bikes on to access the tailgate. That was a huge selling factor!
8th Gear
Acura ZDX hitch option
Here is my hitch and bike rack option i use for carting 2 bikes. The setup is:
*Thule Tray 2-bike system
*Standard 2" to 1 1/4" hitch adapter (added 6" to bike rack location)
*Curt Hitch model #11023 (works well under the stock bumper and mounted in 10 min to stock OEM bolt holes)
Class: Class I
Class: Class I
GTW:2000
TW:200
Drill:No
Install Time:20 Min
Rec. Tube Size:1 1/4 "
Finish:Gloss Black
http://imgur.com/a/WI0kL
TW:200
Drill:No
Install Time:20 Min
Finish:Gloss Black
Thanks for all of the input!!
I finally decided on the Curt hitch (11023). It's a little more visible below the bumper, but I felt the quality and look of the Curt hitch was much better. Installation was relatively easy for one person, though could have used an extra set of hands holding the hitch in position while attaching the bolts.
I opted for the Thule T2 917XTR bike rack. This one is 1.25" so does not need the hitch adaptor like frankiefaun's set-up. Here are some pics:
Cheers
Cheers
kryzrolf (07-25-2014)
I still haven't seen one in 2". The two inch receiver is usually reserved for hitches of Class III or higher. My guess is the manufacturers are reluctant to make a Class III given the low tow rating on the ZDX. I can foresee potential lawsuits if cars were damaged due to excessive towing loads.
I ended up getting the curt 1.25 hitch with a Kuat NV rack. I DONT really like how the hitch pin holes Line up on the curt with the Kuat. The rack is barely inserted 2 inches into the hitch before the holes already line up. The hand tightening cam system gets rid of some wobble.. But not all of it. Maybe I'll post a video of the wobble. I read that the curt and Thule combo has very little wobble. I might switch.
I got mine with the factory hitch already on it and don't care for how it sticks out. Thanks for the pic of the Curt/Thule combo. It looks much better so I may look it up and switch it out.
Does the Curt hitch have a place for the wiring harness/coupler to attach?
TitusR (05-01-2014)
Unfortunately, the Curt does not have a place for the wiring harness/coupler to attach like the Acura hitch. It does have two 'loops' to attach chains, though. That was the only thing I liked about the Acura one. All of the hitches I looked at did not have a dedicated place to attach the wiring harness. They all suggested attaching a wire harness to the chain loops using zip ties. Not ideal, I know, but for myself, the likelihood I was going to tow something requiring a wire harness was slim. Hope that helps
Honda9000 (05-01-2014)
OK thanks I thought that was the case. I don't ever plan to tow either but since the factory harness is on it already I was hoping for a place to secure it. I will find some ace to tie it up under there although the log rings are probably out of sight looking at the pics.
