2002 RSX connector 8P??
Old 06-22-2018, 06:43 PM
George Gonzalez's Avatar
Unhappy 2002 RSX connector 8P??
Okay, I'm trying to troubleshoot an electrical problem. The battery light is on, but the battery stays charged just fine. So it's likely a problem in the wiring. Another clue, the current alternator was replaced 2 years ago. 3 of the 4 thin wires in the alternator plug to the ECM show reasonable and low resistance, the white-red one shows infinite resistance. That heads to the ECM, thru a connector called "8P". So to check continuity it sure would be nice to poke at that connector. Unfortunately the shop manual doesn't seem to show its location, peering with a flashlight just shows tape-covered thick cables. Where the heck is the 8P connector? The manual does say it's on the starter harness, but I also can't pinpoint the starter! Dang cables are bundled up so tightly you can't follow the thick ones! Help!
Old 06-23-2018, 02:51 PM
Acura Fanboy
knavekid's Avatar
Download the RSX factory service manual and you can use the included wiring diagrams to troubleshoot your issue. The manual can be found here:
02-06 RSX Service Manual Special Edition - All Contents with Hyperlinks - Club RSX Message Board
NavTool
19
05-16-2014 07:26 PM
KenUA6
02-22-2007 10:02 PM
socalyaser
06-07-2006 07:40 PM
Dreamdtt2000
07-26-2005 11:07 PM
SC TL
04-04-2001 12:41 AM
Quick Reply: 2002 RSX connector 8P??
