diamond pentagon grille 2016 retrofit
Old 11-22-2018 | 04:06 PM
David Jordi Coronel's Avatar
Question diamond pentagon grille 2016 retrofit
hi guys,
i have a 2016 ilx with the company's shield grille and was wondering if the new 2019 diamond pentagon grille is a direct fit. any help would be most appreciated.
thanks all!
Old 11-22-2018 | 06:44 PM
schen72's Avatar
No, it's not. I also have a 2016 and I personally think it's the best looking iteration of the beak.
Old 11-22-2018 | 06:48 PM
aw, man! thanks anyhow for replying.
Old 11-23-2018 | 11:16 AM
DaIll1's Avatar
It would require bumper and headlight change, but, it will "fit".
Old 11-23-2018 | 04:10 PM
well, essentially not if the whole front end has to be replaced, too/
Old 11-23-2018 | 05:31 PM
DaIll1's Avatar
Really comes down to, how much do you want it. It wont need major skills to 'make' it fit, just parts and wrenches, unlike rear wheel drive.
silverTL6 (11-24-2018)
Old 11-26-2018 | 12:04 PM
schen72's Avatar
Buying a whole new front end... would be cheaper to just sell your car and get the '19 model. You'd also need to change the back end otherwise it won't match and I think that would look even worse.
Old 12-07-2018 | 11:36 PM
jerch's Avatar
7th Gear
I agree; the amount of work, time, money, OCD fitment makes it worth to just trade in for the new design if you really like it that much
Old 12-08-2018 | 02:12 PM
i really like the 2019 model, but it doesn't make sense fiscally as i own my 2016 a-spec outright. i'm not down to buy another car right now.
Old 12-11-2018 | 10:25 AM
skarface's Avatar
This guy is doing it on TLXs...maybe there is something someone can come up with for the ILX? https://www.instagram.com/boss02126/
It seems like you just buy the diamond pentagon grille and emblem then cut the grille to fit the old surround trim. Maybe there is more to it?
Old 12-12-2018 | 02:16 PM
schen72's Avatar
It looks like this guy is just using a similar material for his grill replacement. But it's the same original shape. I don't see the big deal. Also, if you actually did somehow fit the new diamond pentagon grill in there, wouldn't it have the CMBS radar sensor cover in the emblem? On the 16 ILX the sensor is sort of hidden below the beak. How would you move it and recalibrate it to the new location?
Old 12-13-2018 | 12:03 PM
DaIll1's Avatar
The beauty is; If you want it bad enough, there's always a way. A coping saw and superglue can do wonders, but I like the look of my '16 A-spec+ better.
Old 12-13-2018 | 12:08 PM
If there's a will, there's a way! Go forth and get it done!!!
Kaywhy201
ILX Performance Parts & Modifications
01-29-2019 09:56 AM
Quick Reply: diamond pentagon grille 2016 retrofit
