List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS
Old 04-04-2012, 11:11 PM
lumyeinjun's Avatar
I've noticed that there is no such list on Acurazine that specifically states all lightweight/performance wheels that clear the factory Brembo brake calipers. This thread is dedicated SPECIFICALLY to wheels that will clear 3G TL models with the factory Brembo brakes. Please feel free to add to my list.
To keep things clean and simple, let's keep the chit-chat to a minimum on here and only post relevant information. Again, this is for BREMBO clearance, not fender clearance or clearance with the base calipers.
Please just copy the most recent list and follow the format with additional information. Post information in this order:
Brand / Model / Wheel Size / Offset / Weight / Link to picture on 3G w/ Brembos (if available)
Here we go:
Performance Wheels that Clear Brembos:
__________________________________________________
Acura A-spec wheels 18x8 +45 (~30lbs)
Acura TL type-s honeycomb wheels 17x8 +45 (24lbs)
Enkei RPF-01 17x9 +22 (16.75lbs)
Forgestar F14 18x9 +29 (22lbs)
Forgestar F14 19x8.5 +35 (????)
Forgestar F14 19x9 +25 (????) (picture)
Rules and Legend:
If you are unsure of the weight of the wheel, please highlight the weight in red font and hopefully someone on here who knows the actual weight will come on here and correct it.
Wheels that do not clear the Brembos will be highlighted in DarkOrchid font. This information will be useful to perspective buyers so that they know what size they can not fit.
Also, lets keep this list in alphabetical order in the case that this list becomes rather large. It will make the information on here a heck-of-a-lot easier to find.
HYPERLINK pictures, don't post photos on the list.
Hopefully somebody on here posts information about Weds Sport TC 105n wheel clearance over the Brembos. I'm hoping to get a set and it's one of the reasons I started this thread. The other reason I started this thread is:
IMPORTANT NOTE: This thread was created with performance in mind. It is up to the buyer of the wheels to decide if the wheel choice would benefit them or not. In my case, although my 17x9 +22 Enkei RPF1 wheels clear the Brembo calipers and are 9" wide, they are NOT the best performance benefit because I can not fit a tire with a section width larger than 235 over them. They clear the brakes, but fender modification is needed to clear the fenders. An ideal setup would have an offset closer to stock (+45) but with a wider-than-stock wheel width (8.5" or 9").
A 17x9 +22 wheel is too aggressive for performance gain because a wide tire can not be used with that particular wheel size. Contact with the fender will occur if a tire with a section width greater than 235 is used. I'm currently running 245/45-17 tires on my Enkei RPF1 wheels and they can NOT be taken to the track. The wheel comes in contact with the fender liner when I make sharp turns.
And if anybody knows a classy looking lightweight 17x9 or 17x8.5 wheel that clears the brembos with a similar-to-stock offset, PM me Let's keep this thread clutter-free.
Beilby (05-05-2012)
Old 04-04-2012, 11:29 PM
lumyeinjun's Avatar
Updated list with more photos hyperlinked:
Advan RS 18x9 +22 (18lbs) (Picture)
Enkei NT03 18x9.5 +22 (????)
Enkei RPF-01 17x9 +22 (16.75lbs) (picture 1 2)
Forgestar F14 18x9 +29 (22lbs) (picture)
Rules and Legend:
Old 04-05-2012, 02:06 AM
lumyeinjun's Avatar
Enkei RPF-01 17x8 +35 (????) (Picture)
Weds Sport SA-70 17x9 +35 (Picture)
Rules and Legend:
Old 04-05-2012, 08:57 AM
Lazer187's Avatar
I think this thread is a Great Idea, as shopping for Rims that clear the Brembos is a PITA!!! Thanks!
Old 04-05-2012, 11:55 AM
Gen7Milan's Avatar
Avant Garde M310 8.5" +35 26.2lbs
Work CR-KAI 8.5" +43 around 23lbs
Enkei ZR2 7.5" +42 around 20lbs
Old 04-05-2012, 03:11 PM
lumyeinjun's Avatar
In order to keep things organized, please QUOTE the latest list and simply add to it using the rules stated in the OP
Avant Garde M310 8.5" +35 (26.2lbs)
Enkei RPF-01 17x8 +35 (picture)
Enkei ZR2 7.5" +42 around (~20lbs)
Forgestar F14 19x9 +25 (picture)
Work CR-KAI 8.5" +43 (~23lbs)
Rules and Legend:
Please quote the latest list and post specs on the wheel diameter. Believe it or not, wheel diameter actually matters a lot because it can change the spoke design on some wheels. One little difference in one parameter can mean all the difference between clearing the Brembos and not clearing the Brembos.
I have italicized your entries on the list because they do not include the wheel diameter. Once you post up all inclusive data, you may un-italicize the font
Oh and thanks for your contribution
Old 04-05-2012, 09:22 PM
bforbrian's Avatar
Not sure how the quoting will work, do you want us to quote the entire post or just the list?
And when we add to the list, do we add below the quote or in the quote?
And as an aside, everyone should keep in mind that these wheels below clear, WITHOUT THE USE OF SPACERS.
Acura A-spec wheels 18x8.5 +45
Volk TE37/LE37T 19x9.5 +35 (picture)
Volk TE37 19x8 +43
Volk RE30 18x9.5 +35 (picture)
Weds Sport SA-70 17x9 +35 (picture)
Work VS-XX 19x9.5 +28 (picture)
Old 04-06-2012, 04:45 AM
lumyeinjun's Avatar
Wow thanks a lot for adding to the list, Brian! You nearly doubled it!
And yes please use the quote function in order to carry on the hyperlinks and font colors from the previous posts into the newer posts. Simply add new entries into the list if you are sure the wheel will clear the Brembos WITHOUT SPACERS.
Brian's post is exactly how I intended this thread to continue.
Old 04-18-2012, 04:11 AM
DC2many's Avatar
bump for more wheels
Old 04-30-2012, 03:10 AM
RPF1+RS3 FTW
AnthraciteAspec's Avatar
Nice list, I want to start tracking my car and need to pick up an extra set of wheels. This is good info man.
Old 05-01-2012, 04:46 PM
lumyeinjun's Avatar
Forgot to add losiglow's rpf1s, IMO they're the BEST performance wheels for the price on the TL, offset, width and weight are perfect for handling.
Also, I'm going to remove the wheels listed by Gen7Milan until there is a follow up support for the wheels he listed. I will gladly add them back to the list when support has been made. No offense, but I just want to make sure there is support to make sure we don't steer any members the wrong way. Thanks for the contribution, though!
Enkei RPF-01 17x8.5 +40 (16.0lbs)(picture) (link)
Volk TE37 19x8 +43
Rules and Legend:
Old 05-03-2012, 07:57 AM
3rd Gear
Beilby's Avatar
Thank you for this thread, I know nothing about cars, all i know is that I would like to give my 06 TL 6spd a bit more pep and one of the ways I would like to do that is through making it lighter. (nothing extreme like some of you guys!)
How are the RPF 01's daily driveability? These seem to be my best choice for a lightweight wheel I just worry about their durability to daily driving on the streets.
Has anyone tried out the Advan RS 18x9's?
Anyhoo thanks again for this thread, this forum is a giant pool of knowledge and a great resource, also a good time killer while my deployment finishes up.
Old 05-03-2012, 08:40 AM
3rd Gear
Beilby's Avatar
One more question, sorry but I am not knowledgeable on any of this =(.
Do all of these rims listed fit fine on a completely stock 3G TL? I just want a set of lightweight rims that look good enough and that I dont have to mod my car any further to fit them, just rims that fit fine on stock!
Old 05-03-2012, 12:06 PM
RPF1+RS3 FTW
RPF1 is your best choice for lightweight, affordable wheels. Just get them in 17x8 +35. Very similar fitment to stock, they will work fine with no issues.
The following 2 users liked this post by AnthraciteAspec:
Beilby (05-04-2012), Eduardoski91 (08-09-2012)
Old 05-03-2012, 10:56 PM
anx1300c's Avatar
Volk TE37 19x8 +43
Forgestar F14 18x8.5 +33 (19lbs 15.5 oz) front
Forgestar F14 18x8.5 +26 (20 lbs 1oz) rear
Rules and Legend:
HYPERLINK pictures, don't post photos on the list.[/quote]
Old 05-04-2012, 11:10 AM
RDX Dad's Avatar
Enkei Raijin 18 x 8.5 +35 (21.4lbs)
Volk TE37 19x8 +43
Rules and Legend:
[/quote]
Old 05-05-2012, 01:56 AM
anx1300c's Avatar
Volk TE37 19x8 +43
Old 05-08-2012, 09:00 PM
JD TL-S's Avatar
Volk RE-30's. Any Forged 1 piece Volk wheel IMO
Old 05-17-2012, 12:46 PM
sunggin's Avatar
Anyone will know if 18x8.5 +25 Varrstoen 2.2.1 will clear the brembos?
Old 05-17-2012, 02:16 PM
Sunkist_EM1's Avatar
I had Enkei rpf1 SBC 18x9.5 +15 and I loved them... I noticed a big differance in the drive also, quick response in the motor
Old 05-22-2012, 12:34 PM
3rd Gear
Beilby's Avatar
A helpful thread like this should be stickied!
Old 05-22-2012, 02:09 PM
Lazer187's Avatar
^+1
Old 05-22-2012, 03:31 PM
Noober's Avatar
My Volks TE37SL 18x9.5 +22 clears. (18lbs)
abates49ers (08-12-2014)
Old 05-26-2012, 01:52 PM
chikia12187's Avatar
will 18x8.5 +30 re30s clear brembo?
Old 06-08-2012, 07:20 AM
Chapter Leader (San Antonio)
TheChamp531's Avatar
f14 19" are 22.5 lb
Old 06-08-2012, 11:44 AM
anx1300c's Avatar
Noober's avatar's boobies will not clear brembos.
The following 3 users liked this post by anx1300c:
justnspace (07-17-2012), lumyeinjun (08-01-2012), Undying Dreams (06-30-2014)
Old 07-06-2012, 12:46 PM
aznboi2424's Avatar
MSR Series 045 18x8 +35 (21.9 lbs) will clear brembos.
Old 07-17-2012, 10:52 AM
D Loke's Avatar
Anyone have experience with Rotiforms? I realllly would like a set of their NUE's. They come in 18x9.5 +25 or +35. Just curious if the concavity will work.
EDIT: sticky please?
Old 07-25-2012, 05:26 PM
dookie320's Avatar
I like this thread but am a bit confused.
Thread Title: List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS
Why would wheels that do not clear the Brembos calipers be in the list?
Old 07-26-2012, 10:09 AM
blah!
brianch's Avatar
Hm.. Would +30 clear? Who owns those wheels in the photo?
Old 07-27-2012, 03:10 PM
RJW_NY's Avatar
From the first post...
This way the buyer knows what offset/size combo is the limit for fitment....
Old 08-01-2012, 01:40 PM
lumyeinjun's Avatar
Correct! Ideally, I made this post so that buyers with Brembos know what WILL fit and what certainly will NOT fit.
Here is the updated list. I have added Noober's Volk TE37SL and aznboi2424's MSR wheels to the list.
Volk TE37SL 18x9.5 +22 (18lbs)
Volk TE37 19x8 +43
Rules and Legend:
And thanks for keeping this place organized, anx1300c
JDBaumbach (10-05-2013)
Old 08-01-2012, 02:08 PM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
damn Randy thats quite a list....
here is my contribution:
Buddy Club P1 Racing QF 17x8 13.60
SSR Type-C (called Competitions in the US) 17x8 14.30
Motegi Racing Trak Lite 2 17x8 14.60
Racing Sparco LE 17x8 14.60
5Zigen Beckets FN-01R 17x8 14.70
Wed's TC-005 17x8 14.90
Wed's TC-105N 17x8 14.90
Motegi Racing Trak Lite 17x8 15.00
SSR Type-C (called Competitions in the US) 17x8.5 15.00
I have 2 excels which have the wheels weight for a lot of brands/sizes out there....if anyone likes i can zip them and attach them to my post...
Old 08-02-2012, 02:16 AM
lumyeinjun's Avatar
wait a minute, Anil... do those clear the BREMBOS?!?! And there are no offsets!
That would be my buddy Aaron, aka Sharksbreath, and iirc he said that there is not much more room for a higher offset. Don't quote me on that though!
And as a reminder to everyone reading this thread:
This is a list of wheels that will clear the FACTORY BREMBO BRAKE CALIPERS. Many of the wheels on here DO NOT clear the FENDER without fender modifications (i.e. fender rolling, fender cutting, fender melting and fender shotgunning) My current wheels (Enkei RPF1 17x9 +22) required extensive fender rolling and several hundred rounds from my 12 gauge.
Old 08-02-2012, 09:34 AM
swoosh's Avatar
^^^ Randy, I checked my spreadsheet and they did not have offset on them as they come in various offsets....they can be a very aggressive or even come in flat faced....
for example, I know Andy (gerzand) is running Motegi traklites on his Type S....The Weds TC105N range from 32 to 49 hence they will clear brembos....
XXR 527's are the TC105N reps....and i have seen couple Type S's running them
as I said, the spreadsheet that I have does not mention the offset....
Old 08-03-2012, 04:36 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Acura TL type-s honeycomb wheels 17x8 +45 are actually 22lbs
Old 01-25-2013, 10:29 PM
bmore07tls's Avatar
im honored you put in your signature lmao
EvilVirus (01-30-2013)
Old 01-30-2013, 07:26 AM
Type Stealth
ShadowAcura's Avatar
Prodrive GC-05F Monoblock 18x9.5 +22 (18lbs) <---- My contribution
Volk TE37 19x8 +43
I added my Prodrives as I test fitted them even though I do not need them anymore
Old 01-30-2013, 09:52 AM
EvilVirus's Avatar
LMAO yeah I revised it a bit because for some reason couldnt fit the original quote.
Old 03-30-2013, 08:51 PM
1QWKTLS
Q_ShipTL's Avatar
I know they won't clear Brembos, but does anyone know how much the 04-06 Base wheels weigh vs the 07-08 Base wheels?
Quick Reply: List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS
