Breezy's TL-S Progress Thread
Old 07-12-2018, 08:15 PM
  #281
BreezyTL's Avatar
Got the rear Coils in, just haven't tightened everything yet. Front driver side fork bolt is still being a pain unfortunately.
Old 07-14-2018, 08:01 AM
  #282
Shadow2056's Avatar
Can't wait to see. What's the fork doing?
Old 07-14-2018, 09:32 AM
  #283
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
gripping the bolt like breezy gripping a freshly baked glazed doughnut!
Old 07-14-2018, 12:12 PM
  #284
BreezyTL's Avatar
You're guilty of it too, don't single me out here. I'm sure everyone agrees, can't pass on the fresh dough!
Old 07-14-2018, 01:29 PM
  #285
shit yes I'm guilty but if I had used me as an example you'd never get that damn bolt out!
Old 07-16-2018, 08:24 AM
  #286
BreezyTL's Avatar
After a long week of the car up on stands and limited time to work on the car I was able to finally get the coilovers installed. It tracks straighter than before lowering it, but I still think I should get an alignment. I did not install the Upper camber arms at this time so should I wait to get the alignment after that or is that something that can be swapped in and not go thru it again? Other than one bolt that was rusted and a bitch to get out, the install went pretty smooth for the first time ever doing it myself. The recommended dimensions, from Tein, are almost a perfect ride height. Not too low and enough to clean up the wheel gap. Damper set at 8 clicks from stiff at the moment and it isn't too bad but thinking of going a little stiffer for more spirited driving. I wanted to paint the calipers but it has been so humid and want to wait for a drier day to apply it. In the meantime I need to find some Brembo Stickers that fit. This week I am going to try and work a little on it after work to get more stuff on it, mainly the short shifter and window roll up mod.
Buddy did a great job on spraying the headlights with clear. They look brand new!
The sum bitch that held me up for days!
Neighbor with the hook up again 2 rear rotors and Akebono Pads for $72
The rears looked so good so I couldn't leave the fronts alone. I have him getting new Front rotors and pads. Once they come, I will probably paint the Calipers at that time. What is the easiest way to compress the pistons on the Brembos?
Initial shot off the jack stands
All buttoned up ready for a test drive.
Hopefully more to come this week.
Old 07-16-2018, 09:15 AM
  #287
90foxnotch's Avatar
That looks great! Looks like the hard work paid off
Old 07-16-2018, 09:34 AM
  #288
Sexy shit, man...
you can compress the brembos by hand, basically...using the old pad for leverage...i have also used a chisel or screwdriver...basically hold one piston back while you compress the other.
Old 07-16-2018, 10:39 AM
  #289
BreezyTL's Avatar
Sexy shit, man...
Worth buying a tool or no?
Old 07-16-2018, 11:18 AM
  #290
or no...
Old 07-16-2018, 11:20 AM
  #291
you can't use most traditional tools anyway...
you'll see when you get them apart.
Old 07-16-2018, 03:16 PM
  #292
Ossman14's Avatar
If you’re going to install the camber arms I’d wait for the alignment. You’ll be back to where you were before.
And the Brembo stickers you can get on eBay.
Car looks good lowered. I was the same way in terms of the ride height, and then within 6 months I lowered another inch or more lol. Just slam it now
Old 07-17-2018, 06:47 AM
  #293
LOL...
it's Stockholm syndrome...
you think, this rides great! lower!
this rides great, a little lower!
this rides great! LOWERRRR
this rides great! maxed out!
Then you go back to stock suspension and you're like, man holy fuck that car used to ride like shit.
Yeah, align after kit install for sure. I bet those bolts won't be easy to get out though.
Old 07-18-2018, 09:23 AM
  #294
BreezyTL's Avatar
Had a couple hours with the misses gone so I decided I would install my CT short shifter and change the cabin filter while it was apart. I don't think the Filter has ever been changed! Pulling this center console apart was a piece of pie. Had it disassembled and put back together in 45 minutes and washed the car since I had a little time left. Pretty disappointed in myself because I didn't check my squegee before drying the car and I dragged a small piece of debri down my hood and fender, 4 scratches in all............. Hoping they are not too deep and can be buffed out. Last thing I want to do is have to get the hood/fender painted. I have no clue where it came from because I wiped the blade off before I used it.
My list of mods left is getting smaller and smaller, finally! I did order, and received, a rear IS250 Diffuser to mount up but thinking that will have to wait till I get back from vacation. I'd like to address the scratches before I go up north and think about it all vacation.
Old 07-18-2018, 11:33 AM
  #295
90foxnotch's Avatar
Short shifter is definitely a nice mod, mine helped a lot along with shifter bushings. If you can fit your finger nail in scratch then all you can do is buff it and it will hide them if theyre not deep youll be all good. Looking good man!
Old 07-18-2018, 12:59 PM
  #296
BreezyTL's Avatar
I can feel a lip with my nail. Hopefully they can be buffed out.
Old 07-18-2018, 01:13 PM
  #297
90foxnotch's Avatar
Very least they will be able to hide them. Take it to a body shop, if it was me Id do a light wetsanding then buff it. It will be fine
Old 07-18-2018, 02:37 PM
  #298
MyGuti's Avatar
Breezy how do you like the new short shifter? Ive been contemplating it for awhile, but a few ppl I talked to said it takes the fun out of shifting....
and car looks great man. The red tails with the KBP is incredible
Old 07-18-2018, 06:30 PM
  #299
sockr1's Avatar
Received 1,158 Likes on 909 Posts
to me the short shifter adds to the shifting experience haha. i've had mine for like 6 years or something and would do it again in a heartbeat!
Old 07-18-2018, 09:37 PM
  #300
BreezyTL's Avatar
Only have about 30 miles on the car this week and only 6 miles today. Initial feel is firm and amazing. The throw from 2-3 is non-existent now. I like it a lot better than before. Can't wait to find time to put my modded slave cylinder in when the stainless clutch line. I'd recommend doing it!
Old 07-19-2018, 01:15 PM
  #301
BreezyTL's Avatar
Does anyone with the Diffuser have any pictures of their install? I am looking to see how far back it is mounted and what modifications are need to clear the rear hook. I know most will be personal opinion but just wanted to see what is out there.
I think I am set on the ride height, maybe another 1/4-1/2 an inch but I don't wanna slam it since driving it will be a pain with dips and what not. I did notice the XLR8 J-pipe and Cat back are not low car friendly since the flanges are and upside down triangle. At this height I have about 4-5 inches of ground clearance to the flange. Any lower may give me some problems. It was hard not to look back at it everytime I parked it, but now it's twice as hard not to. It's kind of an addiction and my GF makes fun of me for it.
Leaving for Vacation tomorrow evening and will be back on the 29th. Once I get back, Upper Camber arms are going on and then over to the shop for a much needed alignment to hopefully eliminate the wobble under slight acceleration and corners. Running out of ideas for her. What should I do next?
Old 07-19-2018, 01:49 PM
  #302
you can grind the triangle, I think...
also, do not lower the front until the rear camber kit...it'll probably visually bump the back up a tad and even it out.
Looks good.
Old 08-09-2018, 11:51 AM
  #303
BreezyTL's Avatar
Well cruising thru the old interwebz again I came across a local dude selling off old back up parts. Snagged these bad boys for a steal!! I will be painting these and swapping out the ones on the car now. These will get timeserts installed to avoid the thread corrosion issues. This will come in handy when I want to change up the colors just paint them off the car and swap them on. Tedious to do but they will turn out better.
Haven't had much time to drive or work on the car in the last couple weeks, but hopefully I can get some time to put the last few parts on.
Shadow2056 (08-09-2018)
Old 08-09-2018, 12:21 PM
  #304
Shadow2056's Avatar
Nice man! Car is looking great! And it's the same with me. I can't stop looking at the thing when I walk into work. Gonna look better when I order the Type S lip today.
Old 08-09-2018, 12:38 PM
  #305
The Brembos are so easy to paint on the car! Resell those!
Old 08-09-2018, 01:05 PM
  #306
BreezyTL's Avatar
Thought about that option too. Sand them down, prime them and sell so the owner can finish to their liking.
  #307
BreezyTL's Avatar
What are these even going for now a days? Maybe I paid too much?
Old 08-09-2018, 01:21 PM
  #308
I have no idea but I found that all parts I bought to have a backup or to make something easier ended up sitting and collecting dust.
In the end, the effort you make removing and bleeding is going to be more than the inconvenience of having to sit down at each corner of the car doing it on the visible surfaces.
Old 08-09-2018, 02:06 PM
  #309
90foxnotch's Avatar
Car is looking great man, BTW my friend and I got some calipers from an RL and sold them for $250. Paid 40 for them!
Old 08-09-2018, 11:24 PM
  #310
Acura TL Builder's Avatar
I just read you thread. I love the KBP very much! You take very good car of it, glad it’s in good hands. Good job on all your mods.
Old 08-15-2018, 07:11 PM
  #311
Jeff
Oh Sickest TL's Avatar
LOL...
​​​​​​​car looks great man !!!
Old 08-16-2018, 06:29 AM
  #312
Old 08-16-2018, 08:12 AM
  #313
BreezyTL's Avatar
​​​​​​​Well look who it is!
Old 08-16-2018, 08:58 AM
  #314
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
Oh Breezy you just remind me of my new pair Brembo caliper that I bought from Centric still sit in my storage closet lol.
since I live in TX I never miss removing those dam corroded bolts and nuts, great work tho.
Old 10-03-2018, 01:55 PM
  #315
BreezyTL's Avatar
Got around to repairing some threads on the calipers. Unfortunately I couldn't extract the bolt that was in the one caliper. I broke multiple easy outs in the process. It got to the point it would be unsafe with a timesert in it so I pulled it apart to inspect how these are made and perform. It was pretty fun to pull them apart. Don't seem to difficult to do a full rebuild.
I have 2 Driver side calipers with threads repaired for sale. One could use new seals.
I plan on doing more work this week/weekend since it is suppose to rain here. Hopefully more pics and story telling to come later this week. Till then, Cheers!
Old 10-03-2018, 03:11 PM
  #316
90foxnotch's Avatar
Good work those look good, Im sure they wont last long
Old 10-26-2018, 01:35 PM
  #317
BreezyTL's Avatar
Well its that time of the year again where the car goes into hibernation. Tomorrow or Sunday she will be put away until April/May. To keep my mind off the car I picked up a project that I have already started on. It is a 1981 Yamaha XS850 that will be converted to a cafe racer. The plan is to strip the saddle bags, luggage rack and front fairing off. Then get the bike running well. Once it starts and runs well it will get new brake fluid, front & rear rotors/pads/tires, new mufflers, and some new turn signals since the current ones are built in to the luggage racks and front fairing. I will ride that around for the time being while saving for a sport bike front end, custom fabbed seat and maybe some new wheels/tires.
Here she is the day it was dropped off at my house.
Pulled the seat off to pull the battery and get a new one. This thing is just filthy from sitting so long.
The rear fender was pretty bad with surface rust, dirt, grease and who knows what else on it. I hit it quick with some cleaner and 0000 steel wool to clean up the rust. It came out a lot better than I had expected. Can't wait to pull the fender and do the whole piece.
The exhaust is in pretty bad shape. Couple shitty patch jobs to try and "quiet" it down a little. After inspecting it the headers look to be in great shape and am hoping to be able to salvage them and get some slip on mufflers to finish it off. If I can do that, that will save me around $350 for a 3-1 system. Hit the headers with some cleaner and steel wool and they have a nice shine to them. They should look great once I pull them off and clean them.
I will definitely document it as much as I can to share with those interested. Winter is long and fairly boring which leads to spending money I don't need to so hopefully this will minimize that. Trying to keep this to less than $1500 to have a good runner. So far I am in it for $300 for the bike with a clean title.
rockstar143 (10-26-2018)
Old 10-26-2018, 02:13 PM
  #318
90foxnotch's Avatar
Nice looking project man, yes it looks dirty but looks like a really clean bike, should be fun
Old 10-26-2018, 02:16 PM
  #319
truonghthe's Avatar
good job with the TL-S, I am no longer living in the snow state and yet mine TL-S still being put away most of the year lol.
Old 10-26-2018, 02:26 PM
  #320
i love projects like this...
Quick Reply: Breezy's TL-S Progress Thread
