Bent front subframe, how screwed am I?
Old 09-11-2018, 08:33 PM
9th Gear
ElmoTheDestroyer's Avatar
Hi,
So, I hit a raised manhole cover and it screwed my alignment up. Took it to the suspension shop and they said the front suspension looked ok when they put it on the alignment rack... He suggested the subframe might be bent and I should take it to a bodyshop.
I have an appointment, but I'm curious... If it can't be pulled straight, how much do you think it will cost to replace the subframe? I'm guessing we will use a junkyard part so I'm guessing that wont be too bad, but how bad will labor be? Subframe sounds very... connected to many things.
Any ideas how much of a bill I'm going to be in for?
Thanks!
Old 09-11-2018, 08:59 PM
Dhiren314's Avatar
Originally Posted by ElmoTheDestroyer
Hi,
Thanks!
rough estimate would be low $1000s
Old 09-11-2018, 10:07 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Subframe? Shouldn't be TOO bad at all.
I'll put things into perspective for you, a shop wanted to charge 2.5 hours of labour to drop my subframe to change out the motor mounts.
Old 09-12-2018, 12:27 PM
BROlando's Avatar
Received 1,166 Likes on 877 Posts
Spindles usually bend before subframes.
In what way is the alignment off?
Old 09-12-2018, 12:28 PM
Received 8,584 Likes on 6,630 Posts
Post the alignment sheet!
ndoghuntsville
05-22-2015 06:35 AM
wd_pearl945
01-04-2015 07:15 AM
SlicCl
05-14-2014 09:11 AM
NYCSilverICEUA7
10-11-2011 02:11 AM
Blind_Shooter
05-29-2009 01:48 PM
Quick Reply: Bent front subframe, how screwed am I?
