02 Sensor Part Numbers & Cross Reference
All,
Here are the 4 OEM part numbers our o2 sensors. Can anyone add the Denso part as a cross reference for people.
Firewall Side
Bank 1, Sensor 1 (top, before the cat) - OEM 36531-RCA-A02
Bank 1, Sensor 2 (bottom, after the cat) - OEM 36542-RDA-A01
Radiator Side
Bank 2, Sensor 1 (top) - OEM 36531-RDM-A01
Bank 2, Sensor 2 (bottom) - OEM 36532-RYE-A01
Firewall Side
Radiator Side
Crayola Myola (01-02-2024)
Updated with Denso part numebrs
Firewall Side
Bank 1, Sensor 1 (top/upstream, before the cat) - OEM 36531-RCA-A02 or Denso 234-5010
Bank 1, Sensor 2 (bottom/downstream, after the cat) - OEM 36542-RDA-A01 or Denso 234-4355
Radiator Side
Bank 2, Sensor 1 (top/upstream) - OEM 36531-RDM-A01 or Denso 234-5010
Bank 2, Sensor 2 (bottom/downstream) - OEM 36532-RYE-A01 or Denso 234-4368
Firewall Side
Radiator Side
Denso is OEM replacement so yes.
I think some may argue NTK is also an OE replacement but either of those will be > Bosch.
I found a Denso matching the OEM parts number provided above. Its about $50 shipping included so ill give it a try. Hopefully it goes out if not i might have a bad cat or a leak somewhere.
n4soccer06 (09-26-2018)
www.oemacuraparts.com Put in your Model year vehicle, and manual transmission and compare the part numbers.
