02 Sensor Part Numbers & Cross Reference
Old Sep 20, 2018 | 08:49 AM
n4soccer06's Avatar
All,
Here are the 4 OEM part numbers our o2 sensors. Can anyone add the Denso part as a cross reference for people.
Firewall Side
Bank 1, Sensor 1 (top, before the cat) - OEM 36531-RCA-A02
Bank 1, Sensor 2 (bottom, after the cat) - OEM 36542-RDA-A01
Radiator Side
Bank 2, Sensor 1 (top) - OEM 36531-RDM-A01
Bank 2, Sensor 2 (bottom) - OEM 36532-RYE-A01
Old Sep 20, 2018 | 10:27 AM
Old Sep 20, 2018 | 12:25 PM
n4soccer06's Avatar
Updated with Denso part numebrs
Firewall Side
Bank 1, Sensor 1 (top/upstream, before the cat) - OEM 36531-RCA-A02 or Denso 234-5010
Bank 1, Sensor 2 (bottom/downstream, after the cat) - OEM 36542-RDA-A01 or Denso 234-4355
Radiator Side
Bank 2, Sensor 1 (top/upstream) - OEM 36531-RDM-A01 or Denso 234-5010
Bank 2, Sensor 2 (bottom/downstream) - OEM 36532-RYE-A01 or Denso 234-4368
Old Sep 20, 2018 | 12:26 PM
Old Sep 24, 2018 | 04:28 PM
Ochoa93's Avatar
8th Gear
So what will be the recomended brand for my TL ? Denso?
Old Sep 24, 2018 | 04:49 PM
Denso is OEM replacement so yes.
I think some may argue NTK is also an OE replacement but either of those will be > Bosch.
Old Sep 24, 2018 | 08:58 PM
Jackass's Avatar
My '05 for sure had a NTK upper sensor in it. I replaced it with a Denso. Unlikely you will go wrong with either.
Old Sep 24, 2018 | 09:02 PM
Ochoa93's Avatar
8th Gear
I found a Denso matching the OEM parts number provided above. Its about $50 shipping included so ill give it a try. Hopefully it goes out if not i might have a bad cat or a leak somewhere.
Old Sep 24, 2018 | 09:20 PM
csmeance's Avatar
upstream or downstream? If upstream can you post the link! I'll buy one too!
Old Sep 24, 2018 | 09:32 PM
Ochoa93's Avatar
8th Gear
Negative mine is downstream. If you tell me which one it is exactly I can send you the link. Theres: Bank 1 Sensor 1 Bank 1 sensor 2 Bank 2 sensor 1 Or Bank 2 sensor 2 (I need the last one)
Old Sep 25, 2018 | 02:18 PM
Jackass's Avatar
I found the upstream on Amazon for about $90 and the downstream for $35. Best prices I could find for the real deal shipped.
Old Sep 26, 2018 | 11:30 AM
Slavica's Avatar
3rd Gear
Are the part numbers same for manual and automatic, I saw on rockauto some note like manual transsmision automatic transsmision
Old Sep 26, 2018 | 11:45 AM
www.oemacuraparts.com Put in your Model year vehicle, and manual transmission and compare the part numbers.
Old Sep 26, 2018 | 11:47 AM
Slavica's Avatar
3rd Gear
Thank you so much.
Old Dec 15, 2024 | 10:35 AM
KEEYZ_2012TL's Avatar
Originally Posted by n4soccer06
All,
Firewall Side
Radiator Side
Will this be the same Denso Ref# for my 2012 TL?
windowlickingood
1G RDX DIY & FAQ
Apr 24, 2011 02:38 PM
pfunka1usa
Jan 18, 2006 10:35 AM
