Changing Instrument Gauge Color
Old 07-22-2005, 06:50 PM
DamnThisHobby'sExpensive!
Acura3.0CL's Avatar
Disclaimer: By using these guides, you are removing us from any liability that is related to any injury that might occur. I would suggest having a friend help you on these installs, if you are unsure about your abilities for any of these projects, get a professional to do it.
Credit goes to: “Vinnie” for the DIY Write Up & Pictures
Estimated Time: 15 – 45 mins
Tools: Philips screwdriver, flathead screwdriver
Instructions:
1. Take the plastic molding around the steering column off. 5 screws underneath hold it together.
2. Stick the thinnest flathead screwdriver into the rectangular edge of the Cruise button. Pry into it and work it outward. Just be careful not to scratch up your car.
3. The Cruise button is a box that pulls out. There is a plug with wires connected to the back of it. Pull the plug out of the back of the box by pressing the release button found at the top. Repeat steps 2 and 3 for the Dimmer button found on the other side of the steering wheel.
4. The Cruise button is a box that pulls out. There is a plug with wires connected to the back of it. Pull the plug out of the back of the box by pressing the release button found at the top. Repeat steps 2 and 3 for the Dimmer button found on the other side of the steering wheel.
5. Pull the black plastic housing off and set aside.
6. All of your gauges and the various components hooked up to them are referred to as your “gauge cluster.” To get the gauge cluster out, remove the four screws holding it in. Pull it out enough to see three plugs, similar to ones found in the Dimmer and Cruise buttons. You may have to work and wiggle to get the cluster out. Unplug the three plugs by pressing the release buttons.
7. You can now take the cluster out completely.
8. On the back of the cluster there should be 5 plastic knobs, 4 big and 1 small. Twist and pull one out.
9. Take out the original bulb by pulling on it.
10. Replace it with the new bulb and put it back into its proper place. Twist it so that it is secure.
11. Do this to all four big bulbs. The large ones are 194/168 wedge base bulbs. The small one is 74, however, be careful of the kind of bulb because some may not fit. To be safe, just change the four big bulbs to the color of your choice. LED’s are probably your best bet.
12. Reverse these directions, carefully putting all the screws back into place.
Before:
After:
The following 3 users liked this post by Acura3.0CL:
dansavi30CL98 (07-10-2011), Duarte12 (01-01-2017), Guynlidia2006 (07-09-2011)
Old 07-22-2005, 09:33 PM
yadadaa
kamdawg's Avatar
wooooaaahhhh. nice buddy. this is a bazillion times better then those indiglo gauges i hate. plus this still has the stock look in the day. props for this. where did you get the led's?
Old 07-22-2005, 10:31 PM
Korean FIYAH!
Musulsa's Avatar
Give props to the brutha who came up with this mod....
A better pic of the final results (from my car). Also for the #74 type bulb you can use an incandescent blue #74 bulb with no problems. If you want to use a #74 LED then you will have to mod the bulb - I strongly recommend using just an incandescent for the #74.
If you don't replace the #74 bulb then your "80 mpg" area will be a bit dimmer than the rest of the gauge. Some people can handle this, other people who are perfectionists will be bugged by this like crazy.
Old 07-22-2005, 10:37 PM
OBs
OBs's Avatar
This doesn't change the color of the dimmer, cruise and moonroof buttons does it? I'm assuming not -- any DYI's on changing those bulbs or is it similar?
Old 07-23-2005, 01:17 AM
Korean FIYAH!
Musulsa's Avatar
Dimmer, Cruise, and Moonroof buttons are not swap outs, you have to remove and solder in a new LED with a resistor in series.
DIY Links:
http://www.ledautomotive.com/HowToGu...uttonHowTo.asp
http://v6performance.net/forums/show...=&threadid=548
Easy if you can handle a soldering iron.
Old 07-23-2005, 04:29 AM
yadadaa
kamdawg's Avatar
props to you then holmes!
Old 07-28-2005, 08:52 PM
OBs
OBs's Avatar
Changed all the bulbs in the gauges and hooked up the 3 plugs to see if the bulbs worked or if I did to turn them 180 degrees to make them work and now my oil light is flashing and the only other light that works is the seatbelt light. Is there a fuse for strictly the instrument gauge or what else could be the problem?
Old 07-28-2005, 11:18 PM
Vinnie's Avatar
Have no fear my friend, I did the same thing. The spedometer lights wont turn on until you plug in the Dimmer button. Also your oil light will turn off as soon as you turn the ignition on and off again.
Old 07-29-2005, 05:23 AM
OBs
OBs's Avatar
Ha.. alright I'll try that.. thanks Vinnie
Old 08-07-2005, 07:17 PM
Sc0rpi0's Avatar
so, where do you guys buy the bulbs? ebay? auto parts store? online store? got links? i want to do this mod!!! awesome instructions vinnie!
Old 08-07-2005, 07:23 PM
Sc0rpi0's Avatar
http://autolumination.com/74.htm
here?
Old 08-07-2005, 07:28 PM
Korean FIYAH!
Musulsa's Avatar
https://acurazine.com/forums/showthread.php?t=172363
Read the second post. I have a list of places to buy bulbs.
Old 08-07-2005, 07:32 PM
Korean FIYAH!
Musulsa's Avatar
I just want to add that you can also change the turn signals to blue, as well as the rest of those lights in the center of the console (high beam, P R N D, etc). You have to remove the back of the gauge cluster (a few screws).
The bulb type is a T1.5 I think (twist in type). You can get premade screw in led bulbs from
http://www.superbrightleds.com/cgi-b....19322&next=50
It's the 4th one down.
Old 08-13-2005, 01:04 PM
PLuGiNn's Avatar
I want Ice White not a fan of blue :P any jap bulbs for white ?
Old 08-14-2005, 12:56 AM
Korean FIYAH!
Musulsa's Avatar
Because the gauges have a greenish-blue filter built into the light transmitting parts, even if you put hyperwhite bulbs into the cluster the gauges will light up the stock greenish blue anyway. They will just be a much brighter version of the stock greenish blue color.
If you'd done a search, you would have found that out.
Old 08-15-2005, 04:36 PM
PLuGiNn's Avatar
sad
Old 08-16-2005, 10:08 PM
Soon to be H22 turbo!
Bigpimpin18's Avatar
[IMG][IMG]CL LED gauges[/IMG][/IMG]
Old 08-16-2005, 10:09 PM
How do u post pics, I wanna show people how mine turned out in green LED's.
Old 08-30-2005, 07:54 PM
Fast Foward>Rewind>Play
Orlando3.0's Avatar
Try Photobucket.com
Upload a Picture and then use therer own link they give you.
It looks like [img]url[/img]
How much does this cost?
Old 10-13-2005, 07:28 PM
green3.0CL
sayanythingrock's Avatar
where is the dome 9 led you recommended i can't find it
Old 10-15-2005, 07:34 PM
Korean FIYAH!
Musulsa's Avatar
Dude I found this in like 10 seconds of searching.
http://autolumination.com/festoon.htm
http://search.ebay.com/search/search...e=search&fgtp=
Old 10-15-2005, 10:07 PM
green3.0CL
have any pics of that, i heard you have to remove some film or something
Old 10-16-2005, 02:24 AM
Korean FIYAH!
Musulsa's Avatar
Not to be rude, but this section is called "Do it yourself."
If you want to find out about it, then do it yourself; it is very easy.
The information here is VERY valuable and FREE info that took me and others trial and error, time and money to glean. It's a bit annoying to be constantly bombarded with requests for MORE info that costs ME time and effort, but you want quickly and for free. There is more than enough info for you to start your own quest to find out about your own car. Go do it. If you want pics of that stuff, how about YOU take them and post them here? Try contributing something before asking for freebies.
If you are afraid to take about your gauge cluster to check it out, then I would respectfully suggest that maybe this is not the right forum for you to be in. "Do-it-yourself" is not for everyone.
Old 10-17-2005, 08:51 PM
green3.0CL
whoa okay well you posted it up so i figured you were knowlodgable about doing it, i guess i am wrong, it has nothing at all with me being afraid of taking out my cluster. but if i don't like the end result why do it. you are saying something is possible it is only natural to want to see the end result. calm down
Old 10-22-2005, 03:13 PM
silvercl3.0's Avatar
ok i have a question, does the needle change color with the lights, does the needle stay white? im thinking about changing the bulbs red and would like the needle red too >> straight JDM y0
Old 10-28-2005, 11:20 PM
666 Speed
artbran's Avatar
Anyone think of replacing the small #74 bulbs that light up the needles and so on? I just did mine yesterday and love them!. I have pics on my phone, but the cables is at my other house. I will download them soon and post them. Along with that, i'll get the digi out and snap a few tomorrow night for better quality.
Old 10-30-2005, 04:11 PM
HEET Miser
duluoz's Avatar
Yeah, Art, not much mention of those two smaller bulbs on the top/front side of the console in this thread. I don't know, maybe the 97s don't have 'em. But I had the one on the right blow out, and I was wondering why I can't tell how much gas I have at night, even with xenon 194s in the 4 other plugs (they make a nice bright blue) -- I even tried painting my needles with Illuminite. Those are important little bulbs, and they do light up your needles. However, they're not 74s, they're smaller. All I had was a spare 74, so I wedged it in/made it fit. So far, so good -- BIG difference.
Old 11-09-2005, 12:17 PM
666 Speed
artbran's Avatar
I had to do them because the greenish yellow color was annoying me. I ordered the 74 bulbs and put them in without a problem. They fit for me. Anyway, something else that i noticed was that now my red seatbelt light doesnt light up anymore. Not sure why, but I like it off without the belt on. I tried disconnecting it and reconnecting it but it didnt work. Yeah well...
Old 12-06-2005, 10:22 AM
sexier than the sexiest
sexytypes's Avatar
Anyone Have Any Ideas To Do This To The Second Generation Cl-s
Old 12-06-2005, 11:06 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,419 Likes on 3,028 Posts
Should be a similar process, you just have to find out what size bulbs you have, and swap in different led bulbs.
Old 12-08-2005, 01:06 AM
O.G.
krazy99cl's Avatar
which size bulb go where?
Old 12-10-2005, 09:45 PM
O.G.
krazy99cl's Avatar
is it just 194 bulbs? please help.
Old 12-11-2005, 12:26 PM
crbnfbr's Avatar
Yes the four larger bulbs are 194/168 and the lone small one is 74. I ordered my bulbs from http://www.superbrightleds.com, I bought the 74 bulb with the socket included.
Old 12-22-2005, 10:09 AM
qwpobird's Avatar
the hardest part is to pull it back - _ -"..
kkk
Old 03-27-2006, 04:28 PM
(Mid-Atlantic)
If you're looking to brighten your green lights, but not spend $$ on led's, you can just take out the cluster with these instructions, and remove the blue film from the bulbs, this makes your gauges glow a lot brighter green. I did this, because the 9 LED bulbs that I bought were too big for the holes in the gauge cluster, thankfully, cuz 9 would be too bright anyway, so I ordered some smaller 6 led bulbs in the mean time though, I took the blue caps off, and it looks a LOT brighter without spending any $$
Before:
After with just the blue caps removed from the bulbs:
I'll post another pic after I get my 6 LED bulbs installed
primrose98 (07-04-2022)
Old 03-28-2006, 06:20 PM
2.4 L iVtec
jumpmanbsktbll's Avatar
anyone changed the leds to red?
Old 03-28-2006, 08:12 PM
(Mid-Atlantic)
U have to remove the green ink stuff on the back of the gauges for the red to shine through
Old 09-30-2006, 04:23 AM
Turtle Charged, Biotcch!!
Sleep_DEPRIVED_Sleeper's Avatar
anyone know the bulb type/number for the SRS, P R N D lights, etc? I'm thinking about changing every single bulb in the cluster....the climate control and clock also...I'm OK with a solder so no worry...except the resistors, what ohmage should i use?
To the OP: How did you make the color to disperse evenly? mine's a little bit dimmer at the top...
Old 09-30-2006, 09:00 AM
Bagel Bomber
Mach30SiR's Avatar
http://www.acura-cl.com/forums/showthread.php?t=181564
i think this about the third time i've hooked you up on the search function.
those bulbs are either 3 or 5 mm leds with a 470 ohm - .25 watt resistor.
I can answer more questions over on that thread to get you through it.
Old 01-03-2007, 12:31 AM
suprachica79's Avatar
Hey, I want to change my gauges to red, what steps do I have to go through with the actual gauges themselves to be able to see the red? And does anyone have pics of it? thx
Quick Reply: Changing Instrument Gauge Color
