Dropped on Megan coilovers....
Old 04-16-2012, 11:32 PM
2ndgentl's Avatar
Old 04-16-2012, 11:55 PM
sIx SpEeD
badeh2's Avatar
Nice hows the ride quality? Is that the lowest it goes?
Old 04-16-2012, 11:59 PM
6mt swapped..smart
AnthraciteTypeS's Avatar
Looks good! Im not the biggest fan of the tl-s wheels but the rest looks
What brakes are those?
Old 04-17-2012, 01:35 AM
03 CLS-6
1foxbody's Avatar
Looks great!! I have a few questions can you go lower, what model of the megans are those, and hows the ride quality? Let me know thanks
Old 04-17-2012, 07:38 AM
2ndgentl's Avatar
2ndgentl
It definitely goes a lot lower but with those TL-S wheels that stick out it will rub if I dont roll the fenders. The ride quality is actually pretty good. I dont bottom out or rub at all, even when I drive it hard, but I do have the struts set to #5 setting, #1 being the tightest, #15 being softest.....so it does slightly bounce but not bad at all. They are the Megan EZ Street series coilovers/adjustable struts......Paid $673.00 shipped. Im honestly happy with them. I also just installed Eibach front and rear sway bars....what a difference! Car stays perfectly level while turning. I just need a better set of tires.....these suck for traction. I might consider rolling the fenders and dropping it a little more.
Old 04-17-2012, 08:09 AM
2ndgentl's Avatar
2ndgentl
......also I need to get a camber kit. What camber kit you guys recommend?
Old 04-17-2012, 09:55 AM
p.diddy's Avatar
ingalls.
Old 04-17-2012, 10:50 AM
2ndgentl's Avatar
2ndgentl
Ingalls are $269 just for the front.....ive seen other brands a lot cheaper than that. Why Ingalls?
Old 04-17-2012, 01:32 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,144 Likes on 4,811 Posts
Are you sure you need the front kit? In most cases, unless youre slammed, only the back is out of spec.
Old 04-17-2012, 01:43 PM
Registered Member
AustinTaper's Avatar
on lowering springs i didn't need a front camber kit, but now with coils I do. Definitely a couple of inches lower though, so there's something to that ^^.
Old 04-17-2012, 02:15 PM
In search of excitement
kingofdust's Avatar
Looks nice man, how do the Eibach front and rear sways compare to the progress? Did you replace the endlinks, and if so, do the endlinks hit your stuts like the moog ones do?
Old 04-17-2012, 05:22 PM
2ndgentl's Avatar
The sway bars made a good noticable difference. It stays flat cornering and its smoother taking turns now. All I replaced was what came with the sway bars...those rubber grommets that get bolted to the frame. I dont know what some of you are talking about it not being that low. Its tucked under the fenders 1/4". I couldnt imagine dropping any lower unless you want a horrible bouncy ride. To me when its REALLY slammed it looks like you just turned a nice sports/luxery car into a kids car. Kinda rice. Its cool with airbags being slammed only when its parked....
Old 04-17-2012, 05:30 PM
civicdrivr's Avatar
You look to be about the same height as me, which IMO isnt that low
Usmcgrunt47
10-13-2023 09:35 PM
emailnatec
29
09-28-2018 04:27 PM
bluetl04
08-16-2016 02:49 PM
us285126
10-02-2015 02:03 PM
4drviper
09-23-2015 07:42 PM
Quick Reply: Dropped on Megan coilovers....
