2G CL Frequently Asked Questions No New Threads Please.
B&M Tranny cooler installed and Transmission DIY FLUSH - detail writeup inside.
Old 08-05-2002, 08:20 PM
  #41
scalbert's Avatar
Originally posted by EricL
The tranny blurbs recommend 175-200 degrees for ATF (YMMV).
Yea, I've seen that but IMO, but I don't think there is enough capacity to get the heat out and transferred to the coolant with the stock set up. Even with the cooler I had surface temps on my external cooler just over 200 F, I wonder what the fluid temp was??
Old 08-05-2002, 08:32 PM
  #42
SilverBullet_RENAMED's Avatar
Now thats hot!
Old 08-05-2002, 08:50 PM
  #43
EricL's Avatar
Senior moment perhaps?
Hey, buddy, I'm staring to worry about you... I've been marching on the "factory cooler" parade for so long that my web-shoes are web-socks.
One of n threads...
http://www.acura-cl.com/forums/showt...ghlight=cooler
I even remember you said it was hot WITH the additional cooler!
So, IMO, the stock cooler is a joke...
So, that leaves the "how much heat can be removed from the transmission" -- hey?
1. Add some temp. sensors (you have a manual... hmmm...)
2. Get an IR thermo from Griot's ($99) -- ok, so it doesn't read the internal temps.
3. Get the biggest B&M and dump into a bucket full of ice water and play dyno hero...
--- Finally, MIke B, over at Comptech was not willing to "spill the beans" on the actual tranny temps they measured. He said the engineer with the data was "elsewhere". However, they did make a decision to sell the HIgh Temp Redline, but then they are more concerned (IMO) with the car with S/C....
So, the statement you made is confusing when you mention the "coolant"...
If you are talking about the flow rate and heat capacity of the ATF, why not suggest some no-guess solutions?
Is there any reason you would know that the internal tranny temp sersor could NOT be used?
Old 08-05-2002, 08:52 PM
  #44
The Creator
soopa's Avatar
archived.
Old 08-18-2005, 03:12 AM
  #45
3rd Gear
sstein's Avatar
I could of sworn that Acura has a recall out on all 01-? cl trannys to have a oil jet cooler ionstalled on the tranny, free of charge due to the overheating issue and Acura is extending the warranty on all auto trannys.
Old 08-18-2005, 03:26 AM
  #46
goldmemberererer
goldmemberer's Avatar
Old 08-24-2005, 06:10 PM
  #47
Don't Mess With Texas
cltypeSLOW's Avatar
link doesnt work
Old 08-27-2005, 02:03 PM
  #48
Mike01s's Avatar
i'm having problems opening this link. it says i am not authorized to view this site. can anyone email me the infor from this link with pics, or pm me them. thanks mike
Old 09-27-2005, 09:54 AM
  #49
Dead-Fox's Avatar
Unfortunately, this link (and thread) is no longer valid.. I hope the original poster sees this and is able to correct it, but I am doubtful...
Old 10-25-2005, 11:34 PM
  #50
Zona992006's Avatar
Hose
Originally Posted by SilverBullet_RENAMED
$42.95 for the cooler from Summit Racing, model 70255. $5 for the extra hose, then about $4.10 per quart for the ATF.
Be sure and not use fuel hose, use a hose designed for the tranny fluid. Fuel line hoses are way too thin to handle this kind of heat.
Old 10-27-2005, 04:22 PM
  #51
2funnn's Avatar
I installed a tranny cooler several months ago and I am running fully synthetic
ATF. It s been shifting great so far. Heat kills automatic transmissions. From what I read in my factory service manuall, our trannies have a built in heater so we don't need to worry about them running to cold.
Old 12-30-2005, 03:32 PM
  #52
CleanCL's Avatar
anyone notice the link is dead on the first post?
Old 02-11-2006, 03:23 AM
  #53
SundanceCL-S's Avatar
dead link guys. help. i was gonna do this sunday. f$%K.
Old 05-16-2006, 07:30 AM
  #54
GayLove's Avatar
wow gotta get this
Old 05-19-2006, 07:57 PM
  #55
big mike 13's Avatar
what else is needed in order to fit this on the car? do i need brackets or do they come with all mounting hardware?
Old 05-22-2006, 12:51 PM
  #56
mefromuic's Avatar
Yeah, fix link please!
Old 05-30-2006, 09:19 AM
  #57
Bagel Bomber
Mach30SiR's Avatar
bump for the fix!
Old 05-30-2006, 08:53 PM
  #58
01 CLS
DutchCLS's Avatar
somebody fix please!!!!
Old 05-30-2006, 08:59 PM
  #59
GreenMonster's Avatar
The only person who can fix the link is the original poster... He hasn't logged in for years:
https://acurazine.com/forums/members/silverbullet_renamed-13817/
Last Activity: 06-24-2004 12:26 PM
Sorry guys, but maybe searching on the CL or TL forum will turn up a DIY thread w/ a link that works
Old 05-30-2006, 09:08 PM
  #60
Edit: Link is broken in the TL thread by the same poster
https://acurazine.com/forums/showthread.php?t=44619
But I did find a 1st gen write up...
https://acurazine.com/forums/showthread.php?t=171841
I drive a 6spd, so this tranny cooler stuff is new to me, but thanks for the headsup Dutch...
Old 05-30-2006, 09:20 PM
  #61
Ok, I found Scalberts threads w/ pics in the FAQ forum:
https://acurazine.com/forums/showthr...threadid=62311
and
https://acurazine.com/forums/showthr...threadid=64043
and
https://acurazine.com/forums/showthr...threadid=73975
here's comptech's install instructions:
http://www.comptechusa.com/store/med...Cooler2005.pdf
Check out some of the stuff in the Transmission forum:
https://acurazine.com/forums/automotive-news-6/
Having the Helms manual would probably be a good idea too...
Old 05-30-2006, 10:40 PM
  #62
01 CLS
DutchCLS's Avatar
Thanks GreenM!!!
Old 07-26-2010, 06:57 PM
  #63
rraypo's Avatar
Help with installing a trans cooler in my 2003' CL Type-S
Hi, I am sorry, but I cannot get your link to load up and I would love to install a cooler on my 2003' Acura CL Type-S. Any chance you could be of some help here to me??? Thanks so much, Ray here in Oregon. rraypo@hotmail.com
Below is a link on how to install the Tranny Cooler on your CL-S and how to do a flush of your transmission with what tools you have at home. This method does work but will take some time.
After installing it, I drove the car around for about 15 miles, and noticed that the car shifted much faster, smoother. The car seems to have really liked the new fluid, but also the help of that cooler keeping it cooler. After I got back home, that cooler was extremly hot to the touch. I tried both hoses, the top one which is the HOT in, was VERY VERY HOT, could not keep my finger on it for more than 1 sec, the bottom for at least 3 secs I could hold it on there. It was defintely working.
I hope this convinces alot of others to do this mod, because you need too. Our cars do not have a tranny cooler and the fluid just boils and most likely it causes the tranny to die. It's about a 2-4 hr project.
Enjoy guys, any questions feel free to ask.
Also Soopa, you can put this up on your site if you wish as well. So everyone can link to it, or you can just put the html on your site too, in case I take it down.
http://home.satx.rr.com/silverbullet/tranny.htm
Old 05-11-2011, 07:16 PM
  #64
jcupps's Avatar
Acura replace the tranny in my 2001 CL at 89k miles....Is the new one any different than the old as far as reliability??
Old 05-11-2011, 07:45 PM
  #65
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,146 Likes on 4,813 Posts
Nope.
Old 06-09-2011, 07:58 PM
  #66
wadeox's Avatar
i had my trany replaced too thatreally sucked but oh well......going to get a cooler soon and mod it up. speaking of mods is there a list of just 01 cl s mods all at one place.....kinda new here thx
Old 10-03-2011, 07:52 PM
  #67
Dalamar's Avatar
Fuck me, I guess I'll add a cooler to mine in a few weeks and make a write up for it.
mada51589
05-03-2022 08:54 PM
cobra10363
01-16-2021 08:12 PM
cycdaniel
12-17-2019 10:58 AM
HeloDown
09-08-2015 06:51 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: B&M Tranny cooler installed and Transmission DIY FLUSH - detail writeup inside.
