Anyone Put Eibach Pro-Kits on the TLX V6? Camber kit?
Old 09-20-2018, 06:06 PM
5th Gear
ScoopForDays's Avatar
Lightbulb Anyone Put Eibach Pro-Kits on the TLX V6? Camber kit?
I really want to lower my 18' TLX A-Spec and pretty much only looking at the Eibach Pro-Kits for a website estimated 1.5"/1.0" drop. They "highly recommend" the adjustable rear camber kit, but that's another half grand so that's got me on the fence. Unfortunately the other set of Pro-Kits they have for a mild 1.0"/0.7" drop that does require the rear camber kit is only for the 2.4L TLX which I assume is because of different tuned shocks or dampers, idk.
Has anyone else have experience in putting in the Eibach Pro-Kits or any other lowering springs on a V6 TLX? Any issues with the stock shocks/dampers or bad camber tire wear?
Old 10-02-2018, 02:26 AM
FZ427's Avatar
I got the Eibach springs, my rear camber now is -2 degrees, can’t tell you on tire wear cause I only drove 500 miles since I installed the springs. So far very happy, no more wheel gap.
Old 10-02-2018, 06:34 AM
Received 16,260 Likes on 11,971 Posts
Camber doesnt actually wear tires.
out of spec TOE wears out tires.
for my generation TL; the camber spec is up to -1.7.... and I think my lowering springs did bring it out to -2... aint hurt a thing
Old 04-02-2019, 03:43 PM
7th Gear
Ek9max's Avatar
Back from the dead.
How was your tire wear without the camber kit?
Old 04-03-2019, 01:07 AM
FZ427's Avatar
Originally Posted by Ek9max
Back from the dead.
well when I lowered the car, the car had only 1400 miles. Now the car has close to 4000 miles and tires look with no tire wear.
Old 04-03-2019, 01:11 AM
7th Gear
Ek9max's Avatar
So no camber kit needed in your opinion?
Old 04-03-2019, 02:47 PM
FZ427's Avatar
well now the rear is -2, I might have some inner tire wear in the future. Also depends how you drive, how are the roads in your area and how much you drive the car, if you drive let’s say 20k miles a year I would get the rear camber kit.
Old 03-25-2021, 10:39 PM
4th Gear
Jonathan Liew's Avatar
on Eibach Pro Kit, no camber needed.
Eibach Pro Kit 1.3" Drop front and back
Old 09-03-2021, 11:31 AM
BMArias15's Avatar
have you checked the tire wear? Just lowered mine on H&R and have -2 rear camber. Curious on needing camber kit due to tire wear. I might start a new thread about my car and post pics along with my alignment results paper.
fireman252525
04-05-2010 08:56 AM
cambo
1G TL Tires, Wheels & Suspension
07-05-2005 11:45 AM
Belzebutt
10-20-2004 09:17 PM
farberstyle
05-08-2003 05:45 AM
Quick Reply: Anyone Put Eibach Pro-Kits on the TLX V6? Camber kit?
