Key Fob Low Battery Notification Incorrect
Old 09-13-2018, 11:12 AM
fishheadbarandgrill1's Avatar
2015 RDX continues to give me a notification that my key fob battery is low. Battery has been changed and I still an intermittent notification of the low battery. Any help with this?
Thanks,
Bob in Raleigh, NC
Old 09-13-2018, 07:31 PM
Carbon Bronze Pearl 2008
Carbon2008RDX's Avatar
Thanks,
Bob in Raleigh, NC
Where does the "battery is low" notification show? Is it on the fob itself or something on the dash in the RDX?
Old 09-13-2018, 07:47 PM
The indication is on the dash.
Old 09-14-2018, 03:17 PM
RenoTL's Avatar
I’ve posted this before. I had a similar issue where the dash MID showed the FOBs battery needs replacing yet I had already replaced it. For me, I opened the FOB and reset the battery in its place. As I recall, the battery is at a slight angle when it is set into place.
Old 09-23-2018, 09:17 PM
samiam_68's Avatar
Just replaced mine and the warning went away on its own. Make sure the new battery is seated correctly - put it in at a slight angle towards the back, push in, then down until it clicks into place. Don't use force.
Carbon2008RDX (09-23-2018)
Old 09-25-2018, 12:18 AM
Ironically, I just replaced the battery in my key fob for my 2016 RDX Advance. The dash alerted me with a big orange warning the fob battery was low earlier today. I was like crap! I've only had the car for 2 1/2 years. Expected the battery to last longer than that but guess not. Anyway, I wasn't sure how to replace it so did a little research. Do NOT, and I mean do NOT pry the fob back open with a screwdriver or you'll almost guaranteed to scratch it up or worse. Here is the best and super simple way to change the battery. Enjoy!
MerlinT (09-25-2018)
Old 01-29-2019, 12:09 PM
Craig Hall's Avatar
I can’t tell from the video how he uses the key insert to open the fob
Old 01-30-2019, 06:15 PM
RenoTL's Avatar
Once you remove the physical key from the fob, on the opposite side from where the key goes in, there is a small depression where you can use a coin to spread about the 2 half's of the fob.
Old 01-30-2019, 11:48 PM
charlie65's Avatar
Mine lasted just over 2 years, so I put a reminder on my phone to change it every second year.
Negative1
05-11-2014 11:53 AM
Sgt128
3G MDX (2014-2020)
02-23-2014 09:39 AM
computecker
4G TL Problems & Fixes
08-10-2012 11:30 AM
inkonspikuos
02-01-2008 03:41 PM
Quick Reply: Key Fob Low Battery Notification Incorrect
