Annoying noise while driving.
Please forgive if its been posted before. Annoying noise from 2010 3.7 TL. 108K miles on it, Dealership said its upper control arm. Its been replaced. Noise is still there. Seems like its coming from drivers front side. Seems to increase with speed. No noticeable vibration from steering wheel. Bad bearing? Shitty tires?
Link below.
https://drive.google.com/open?id=1zR...uK0t8cXJbLXO1B
Thank you all.
Link below.
Thank you all.
Maks (08-17-2018)
Did the dealer replace the control arm due to the noise? If so, they're morons. Suspension components usually cause clunks or more "sudden" noises when bad. That's a whirring kind of noise. Wheel bearing, tires, something rubbing, etc. Like Mossman said, rotate the tires and see if the noise changes.
Maks (08-17-2018)
Morning all! I don't want to start a new thread for different kind of noise. Seems like my exhaust is leaking somewhere. Funny thing is that noise appeared right after I did my brakes and rear calipers!
https://drive.google.com/open?id=1Ev...xdy1jeI5oZCYVn
I'm not sure I understand. You said the upper control arm was replaced but the noise was still there. Then you replaced it (again?) and the noise went away.
Not sure on that noise. It sounds like the resonator has been removed. Any modification to the exhaust?
I think I had a similar sound in my car: https://www.youtube.com/watch?v=bJpL...ature=youtu.be
Replaced the wheels. When taken off you could literally feel bumps of uneven wear. Mechanic said to replace suspension and wheels. did both and now I'm at around 20k miles on new equipment and all has been fine.
Gasket after the cat converter completely rusted through! That was the noise. My shop got 3 or 4 ones from NAPA and none of them were right! I ended up going to Acura dealership to pick one up. They wanted $16 for it. After I showed them online price of $6, they just gave me one for free!!
optomos
10-17-2012 05:33 AM
super20g
1G TSX Problems & Fixes
01-31-2011 12:42 PM
