Random Technical Talk
Old 07-02-2013, 10:21 AM
  #161
Needs more Lemon Pledge
stogie1020's Avatar
Received 2,000 Likes on 1,173 Posts
I switched back to FF from Chrome a few months back and have been happier for it.
Loved chrome but it started to be really unstable for me. FF is good.
Old 07-25-2013, 05:13 PM
  #162
srika's Avatar
Received 9,968 Likes on 5,137 Posts
Dell finally figured out how to make a laptop as thin as a Macbook. I see this in my future.
and damn is it something.
<object height="480" width="853">
<embed allowfullscreen="true" allowscriptaccess="always" type="application/x-shockwave-flash" src="//www.youtube.com/v/NyOE9R0AnQs?hl=en_US&version=3" height="480" width="853"></object>
http://www.engadget.com/2013/07/25/d...n-at-siggraph/
Dell officially unveils Precision M3800 workstation at SIGGRAPH, gives rumored specs a nod
By Sean Buckley posted Jul 25th, 2013 at 2:39 AM 66
<hr>
Remember that Haswell-powered Dell workstation that popped up last week? The company is officially ready to acknowledged its silicon, announcing on its corporate blog that the machine is being unveiled at SIGGRAPH this week. Dell is still reluctant to get into specifics, but confirmed on a teaser page that the Precision M3800 would contain a 4th Generation Intel Core-i7 CPU, NVIDIA Quadro graphics and a 3,200 x 1,800 QHD+ multi-touch IGZO display. Even better, all that is set to fit into a tight 0.7-inch chassis that weighs in at 4.5 pounds. Mum's still the word on specifics, but previous leaks assigned the machine 15GB of RAM and either a 1TB HDD or a 512GB SSD. Dell hasn't let the workstation's price slip either, but we don't expect it to be cheap -- nothing thin and powerful ever is.
Old 07-26-2013, 02:51 AM
  #163
Go Giants
Whiskers's Avatar
Received 1,231 Likes on 821 Posts
Meh, Dell...
Old 07-26-2013, 07:49 AM
  #164
doopstr's Avatar
Received 2,049 Likes on 1,135 Posts
Precision Workstations are very nice.
Old 08-02-2013, 12:06 PM
  #165
TeknoKing's Avatar
I'm losing my marbles here. So I have a dual monitor setup at this station at work. Left monitor is perfect color. Right one has a blue tint.
I've adjusted the right monitor OSD settings to everything possible, the blue tint remains. I've changed the DVI cable, nada. I swapped the DVI cables between the monitors, expecting left show blue tint now and the right one to be perfect - well Windows is being a smartass and remembers the identity of the monitors when I swap, so this did nothing! I've replaced the monitor with a different one, same blue tint on the replacement. o_O
What the f@ is going on. Swapping DVI ports - no difference. Swapping monitors - no difference. Replacing DVI cables - nothing. I connected one monitor (the right one by itself), same blue effen tint. It's like it knows when I connect everything but the left monitor. What kind of voodoo is this shit? Ideas?
Basic AMD 7700 GPU - nothing fancy, but if it was not working, swapping ports would have showed the difference right away. Windows is fucking with me? I've tried 3 other monitors, so it's not the monitor.
Old 08-02-2013, 12:12 PM
  #166
Sanest Florida Man
#1 STUNNA's Avatar
Received 10,118 Likes on 6,107 Posts
Is there a way to adjust color setting in AMD Catalyst control software. They should give you advanced settings to tweak color profile or gamma or whatever it is that's causing the issue.
Old 08-02-2013, 01:19 PM
  #167
TeknoKing's Avatar
Yep, I've played with that as well. I went as far as even creating new profile just for that monitor, but regardless what I do, the blue tint remains. I'm just puzzled as why it's doing this. I also can't get the monitor to show white as daylight white, it shows as a higher temp, but when I verify the monitor is locked in 6500K as default, which is what it should be on.
I'll try to swap the GPU.
Old 08-07-2013, 05:16 PM
  #168
srika's Avatar
uh, does anyone know how to fix jadeclick IE search redirect? I checked all the regular stuff and am unable to fix it. Have tried Spybot, Malware Bytes, Superantispyware, TDSkiller, Combofix, but I didn't try the first 3 in Safe mode - not sure that would make a difference... also checked various other things as recommended at sites... but this bugger just won't go away....
thanks in advance for any help
Old 08-08-2013, 01:18 AM
  #169
Go Giants
Whiskers's Avatar
Always run SAS or MBAM in safe mode. Also try Norton Power Eraser.
Old 08-08-2013, 08:42 AM
  #170
TeknoKing's Avatar
^ I'd try a bootup Kaspersky... It's free, leave it for full scan it usually does the trick...and IE? We don't let friends use IE... Ever.
https://support.kaspersky.com/4162
Old 08-08-2013, 10:52 AM
  #171
Sanest Florida Man
#1 STUNNA's Avatar
I've had decent results with MS Safety Scanner
http://www.microsoft.com/security/sc...s/default.aspx
Old 08-08-2013, 10:58 PM
  #172
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
jadeclick IE search redirect? Never heard of it and a Google/Bing search turns up nothing....
What are the symptoms? What site/s are you being re-directed to?
Old 08-09-2013, 08:39 AM
  #173
TeknoKing's Avatar
I need to block Facetime over any iDevice on my network. I've blocked all ports Apple has instructed to keep open for it to work, but it's still effen connecting... Ideas? Thanks.
Old 08-09-2013, 09:01 AM
  #174
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
http://support.apple.com/kb/TS1629
Good lord it uses a lot of ports for one service! Lol
No ideas here...
Old 08-09-2013, 09:18 AM
  #175
TeknoKing's Avatar
those ports are useless and are blocked.. I need to block an IP range or something.
Old 08-09-2013, 10:32 AM
  #176
Go Giants
Whiskers's Avatar
http://support.apple.com/kb/ht4245
Old 08-09-2013, 10:35 AM
  #177
srika's Avatar
thanks guys - I did try the scan and TDS in safe mode and it didnt get it. Also tried MS safety scanner. bugger is in there good. had to re-image the machine. :banghead:
Old 08-09-2013, 10:36 AM
  #178
TeknoKing's Avatar
Thank you, those I've blocked earlier. It still works, lol. I won't block 80 or 443, but the rest are blocked. Video is still transmitting.
Old 08-09-2013, 10:40 AM
  #179
Go Giants
Whiskers's Avatar
Give up....
Old 08-09-2013, 08:55 PM
  #180
Sanest Florida Man
#1 STUNNA's Avatar
This better not be the one I got you...
Old 08-09-2013, 08:56 PM
  #181
srika's Avatar
no way. I never have trouble like this with personal machines. :p
that thing is sweet as hell btw, I use it as an ultra-portable photo editing workstation - I can run all of the photo programs I use on my desktop and bigger laptop on it, pleasantly.
Old 08-09-2013, 08:57 PM
  #182
Sanest Florida Man
#1 STUNNA's Avatar
If it's a rootkit in the MBR of the drive a reinstall probably won't fix it...
Old 08-09-2013, 08:59 PM
  #183
srika's Avatar
not my problem anymore, haha
Old 08-11-2013, 12:46 PM
  #184
Sanest Florida Man
#1 STUNNA's Avatar
Anyone know of a good 3rd party SSD Optimization TRIM tool for XP? I bought a San Disk SSD for a client and they don't make any SSD software, they said to use 3rd party tools but didn't bother to recommend any.
I don't think you can run Intel's SSD Toolbox on non Intel SSDs...
Old 08-11-2013, 01:43 PM
  #185
mcflyguy24's Avatar
No clue, but you still use XP?
Old 08-11-2013, 03:15 PM
  #186
Sanest Florida Man
#1 STUNNA's Avatar
Not me. It's for a client of mine
Old 08-11-2013, 06:20 PM
  #187
Weese's Avatar
i believe support will cease for xp after the end april 2014. you should recommend updating the OS while getting the trim support that you need.
Old 08-11-2013, 08:15 PM
  #188
Sanest Florida Man
#1 STUNNA's Avatar
Yeah that's not going to happen. As long as that thing still runs it will stay there. It's the back office PC at a restaurant.
Old 08-13-2013, 10:23 AM
  #189
Sanest Florida Man
#1 STUNNA's Avatar
Getting real tired of Brighthouse's shit...
Old 08-13-2013, 11:30 AM
  #190
srika's Avatar
someone I know wiped his android phone - BY ACCIDENT - because it had got 10 invalid logins while in his pocket. lmao
The following 2 users liked this post by srika:
#1 STUNNA (08-13-2013), maharajamd (08-13-2013)
Old 08-13-2013, 01:33 PM
  #191
srika's Avatar
Hate this crap.. why the F would I want to download the stupid app when I can download the mp3 directly at the below link? Too bad many people will click to download the app just because they don't know to click below. This is Amazon taking advantage of those people, by making them download the app. hate companies that do that. (This is Amazon btw)
Old 08-13-2013, 04:09 PM
  #192
Sanest Florida Man
#1 STUNNA's Avatar
had the guy come out today and he reconfigured some of the outside cables and updated my modem firmware. Much better...
Old 08-17-2013, 09:04 AM
  #193
Sanest Florida Man
#1 STUNNA's Avatar
Google goes dark for 2 minutes, kills 40% of world's net traffic
Systemwide outage knocks every service offline
http://www.theregister.co.uk/2013/08/17/google_outage/
Anyone else notice this last night? I made a thread about it but of course it came back as soon as a posted it so I deleted it. I was trying to get into a clients email when it happened
Old 08-17-2013, 10:49 AM
  #194
Go Giants
Whiskers's Avatar
Old 10-01-2013, 02:04 PM
  #195
srika's Avatar
LMFAOOOOOOOOOOOOOOOOO
http://arstechnica.com/gadgets/2013/...s-by-up-to-20/
Old 10-14-2013, 10:28 AM
  #196
speedemon90's Avatar
Put windows 8.1 (or at least I believe its the 8.1 preview version) on my macbook pro last night. Haven't tested it out yet really, but will be doing that whenever I need to use windows.
Whats the main difference between 8 and 8.1?
Old 10-14-2013, 10:33 AM
  #197
Sanest Florida Man
#1 STUNNA's Avatar
Start button
Old 10-14-2013, 11:26 AM
  #198
Start button
maybe I dont have the start button or this is an old build? The start button just takes me into metro mode.
I knew that was one of the things and I was looking out for that.
Old 10-14-2013, 11:35 AM
  #199
Go Giants
Whiskers's Avatar
Thats all it does.
Old 10-14-2013, 01:31 PM
  #200
Mizouse's Avatar
Received 2,773 Likes on 1,976 Posts
Quick Reply: Random Technical Talk
