Apple: macOS formerly OS X News and Discussion Thread
Old 12-11-2014, 07:44 PM
  #321
Go Giants
Whiskers's Avatar
Received 1,231 Likes on 821 Posts
MBP arrived... doing the Yosemite upgrade right now... Any MUST HAVE items I should install? W7Pro license does not arrive until Monday so I have to wait until then to load bootcamp...
You can install 7 and activate it later.
Get a good case for it.
Old 12-11-2014, 08:35 PM
  #322
Needs more Lemon Pledge
stogie1020's Avatar
Received 2,000 Likes on 1,173 Posts
Yeah, I realized that and am installing it now.
Any MUST HAVE software for the osx side?
Old 12-11-2014, 08:45 PM
  #323
Go Giants
Whiskers's Avatar
I like Hyperdock (paid app) Facebook Tab Pro (paid) Onyx (free)
stogie1020 (12-11-2014)
Old 12-26-2014, 08:50 PM
  #324
I shoot people
is300eater's Avatar
Received 2,786 Likes on 1,409 Posts
so, I have a 2010 MBP and would like to install a SSD... when I search online, what words should I be searching for? Are there specific models only for MacBook Pros for that year? Sorry for the noob question
Old 12-26-2014, 09:15 PM
  #325
Go Giants
Whiskers's Avatar
Most should be fine.
Old 12-26-2014, 09:19 PM
  #326
I shoot people
is300eater's Avatar
so, they are all the same size? (dimension wise)
Old 12-26-2014, 09:32 PM
  #327
Go Giants
Whiskers's Avatar
Yep, any 2.5 inch should be fine.
The following 2 users liked this post by Whiskers:
#1 STUNNA (12-27-2014), is300eater (12-26-2014)
Old 12-27-2014, 12:44 AM
  #328
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
I put in the Samsung 512GB 850 PRO and it's incredible. 10 year warranty, 3D memory, no reduced performance over time, and no need for TRIM to be enabled
My 17" 2010 MBP boots in 12 seconds flat vs 3 minutes with 500GB 7200 RPM drive.
The following 3 users liked this post by csmeance:
doopstr (12-27-2014), is300eater (12-27-2014), Mizouse (12-27-2014)
Old 12-27-2014, 03:44 PM
  #329
Mizouse's Avatar
Received 2,773 Likes on 1,976 Posts
yea the samsung pros are good SSDs.
I just got and am booting my mac mini via USB3.0 a 250GB Samsung 840 EVO. HOLY SMOKES this thing flies!
Its like 400MB/sec read/write
Old 01-03-2015, 03:36 AM
  #330
Mizouse's Avatar
ok this is really annoying me, but im currently using my old win 7 pc as a sort of file server and sharing it with my mac mini via SMB since my win7 PC has an assload more storage space.
but whats annoying is that the connection is VEERRRRRY slow. I cant even stream videos, movies and prawn from it because the transfer rate is slow.
i used the blackmagic disk test and got about 1MB/sec something doesnt seem right about this.
BTW i also did a quick search and saw that if i connect instead with "CIFS://" instead of "SMB://" it would rememdy it. nope.
I was reading that there is some issue about SMB2 vs SMB1
any clue on how to fix this?
Old 01-03-2015, 05:46 PM
  #331
Go Giants
Whiskers's Avatar
Wired or wireless network?
Old 01-03-2015, 06:44 PM
  #332
Mizouse's Avatar
my desktop is wired and the mac mini is on a wireless N network
Old 01-03-2015, 06:55 PM
  #333
Go Giants
Whiskers's Avatar
Try playing with the channel of what the router is on. Macs get weird that way.
Old 01-03-2015, 10:46 PM
  #334
Sanest Florida Man
#1 STUNNA's Avatar
Received 10,120 Likes on 6,108 Posts
Use istumbler!
Make sure none of your wifi channel isn't conflicting with any other channels nearby. Use channel 1, 6 or 11. That's only for 2.4ghz.
https://www.istumbler.net
Ken1997TL (01-03-2015)
Old 01-03-2015, 10:59 PM
  #335
Mizouse's Avatar
Old 01-04-2015, 08:48 AM
  #336
doopstr's Avatar
Received 2,049 Likes on 1,135 Posts
Try testing with FTP. You can install filezilla server on the windows box pretty easily. Report back on if transfer is fast or slow.
https://filezilla-project.org/download.php?type=server
If transfer is fast I would suggest that you ensure that your windows box and router has the latest drivers/firmware. I used to have weird problems like you describe but it went away. It was probably fixed by some update.
Also check some basic stuff like making sure that your Win7 PC is running its nic at 1Gb/Full duplex. Check the MTU also.
Old 01-04-2015, 01:02 PM
  #337
I shoot people
is300eater's Avatar
with my 2010 MBP, is it okay to keep it plugged in at all the time? Or I should occasionally unplug it and let the battery run down?
Old 01-04-2015, 01:11 PM
  #338
nnInn
jupitersolo's Avatar
Received 1,084 Likes on 646 Posts
With any laptop, best to unplug and run down. Keeps battery "fresh" if you will. I had a HP, that was basically a desktop. Battery died, just the same from never unplugging.
is300eater (01-04-2015)
Old 01-07-2015, 04:40 AM
  #339
I shoot people
is300eater's Avatar
...got myself the SSD and RAM upgrade... finally had it installed (by my wife... yeah, she's the geek in the house lol). So far, with browsing, it's quite noticeably fast! It'll be interesting to see how post processing photos will be with Lightroom
The following 2 users liked this post by is300eater:
Mizouse (01-07-2015), Whiskers (01-07-2015)
Old 01-07-2015, 09:50 AM
  #340
Mizouse's Avatar
The best part about it is loading apps. For me at least it's almost instant on some.
Old 01-07-2015, 10:17 AM
  #341
stogie1020's Avatar
Question about my new MBP.
It takes a few seconds longer (like 10-20) to shutdown than I would like.
I run teamviewer at start up and I think this may be causing the delay during shutdown. Any way to speed up the shutdown time?
Old 01-07-2015, 10:30 AM
  #342
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
^Make sure "reopen apps" isn't checked and you can edit the kill times.
Terminal
sudo defaults write /System/Library/LaunchDaemons/com.apple.coreservices.appleevents ExitTimeOut -int 1
sudo defaults write /System/Library/LaunchDaemons/com.apple.securityd ExitTimeOut -int 1
sudo defaults write /System/Library/LaunchDaemons/com.apple.mDNSResponder ExitTimeOut -int 1
sudo defaults write /System/Library/LaunchDaemons/com.apple.diskarbitrationd ExitTimeOut -int 1
sudo defaults write /System/Library/LaunchAgents/com.apple.coreservices.appleid.authentication ExitTimeOut -int 1
And clear your kext cache
Terminal"
sudo chown root:admin /
enter your password
sudo kextcache -system-prelinked-kernel
sudo kextcache -system-caches
Open System Preferences
Open Startup Disk
Ensure Startup Disk is still set correctly
Reboot
stogie1020 (01-07-2015)
Old 01-07-2015, 11:42 AM
  #343
Go Giants
Whiskers's Avatar
Quit mail if its open before shutdown.
Old 01-07-2015, 05:58 PM
  #344
stogie1020's Avatar
Warren, previously you said to get a good case for the MBP, so I got one of those plastic shells with the piece that clips on the top and the second piece for the bottom.
It drives me crazy. It sticks up above the edge of the front of the laptop body and when I type it digs into my wrists.
Do you have any suggestions for a decent one?
Here is what I got:
13-Inch Rubberized Frosted Hardshell Case Cover for MacBook Pro 13.3" with Retina Display (NEWEST VERSION)A1502 /A1425 (Do Not for 13.3" Aluminum Macbook Pro A1278)-Clear - Newegg.com
Old 01-07-2015, 06:52 PM
  #345
Go Giants
Whiskers's Avatar
Yay - Photoshoot!!!!
stogie1020 (01-08-2015)
Old 01-07-2015, 06:58 PM
  #346
Go Giants
Whiskers's Avatar
Macbook has carbon fiber skin full body, with a Moshi screen protector the case is from Thule and on the bottom is a neat kickstand from
Bluelounge Bluelounge
- Click the links in my text for info.
Old 01-07-2015, 07:01 PM
  #347
Go Giants
Whiskers's Avatar
The Iphone 6 plus has a carbon fiber skin and a clear full case - looks great and the Ipad mini has an origami carbon fiber case as well.
I have carbon fiber as the wallpaper for all three devices and they look very good and protects well.
Technology should be beautiful.
  #348
Go Giants
Whiskers's Avatar
Ill photo shoot my Surface Pro 3 and Windows and Android tablet later. They look great too.
Old 01-07-2015, 07:22 PM
  #349
stogie1020's Avatar
Is there any protrusion of the MBP cover over the front edge to the left and right of the trackpad?
EDIT: Just watched the application video, it's a skin.
Old 01-07-2015, 07:24 PM
  #350
Go Giants
Whiskers's Avatar
none
Old 01-07-2015, 07:42 PM
  #351
stogie1020's Avatar
I knew I would get what I paid for for $16...
Apparently the Speck hard shells have their two attachment points for the front bottom piece on the sides so that the entire front edge is lower than the MBP itself... $50 for a Speck or a skin...
Dremmel tool, here I come.
Old 01-07-2015, 08:23 PM
  #352
doopstr's Avatar
I feel a lot better knowing that he puts all his gear in condoms.
Old 01-07-2015, 08:28 PM
  #353
Go Giants
Whiskers's Avatar
I don't think my Iphone has even been in contact with human hands.
Old 01-07-2015, 10:59 PM
  #354
Mizouse's Avatar
kinky!
Old 01-14-2015, 09:07 AM
  #355
Oliver!!!
litesout's Avatar
So, the GF's Mac is giving her a ton of issues lately. I think its mostly because she's running an old version of OSX and can't update Firefox to a remotely current version. Chrome isn't an option either. I think it's an Early 2008 Intel C2D 2.4 Macbook. Currently she's running OSX 10.5.8.
Please correct this if I'm wrong, but I read somewhere that 10.7.5 is the highest version of OSX that I can install on that particular machine. Really wish I could remember where I read that. Anyway, I'd like to update her to the latest version possible. What's the upgrade path from 10.5.8? Do I have to install an interim version (10.6.x) or can you just jump straight to whatever the latest supported version is? I'd prefer to jump to whatever the latest version is as it seems Apple charges for each upgrade. Its also important that she not lose anything in the upgrade process. She has a lot of job related stuff on there that it would be next to impossible to replicate. I'm going to try to scrape together an external hard drive for her to back everything up on before we do anything, but if we can avoid losing anything in the first place, that would be preferable.
I know she should just get a new one and move on, but in reality she doesn't need it. She really doesn't do anything with this one other than surf the web, use iTunes to put stuff on her iPod and use MS Office.
Old 01-14-2015, 10:09 AM
  #356
maharajamd's Avatar
Back everything up first.
Since it's Intel you can certainly upgrade. How far depends. If it's a "Late" 2008 with 2+GB or ram Mavericks is possible.
You'll first need to upgrade to Snow Leopard (10.6.x) to get the app store app. Then you can use the app store to upgrade to Mavericks.
Enjoy.
Edit: I should read everything first eh? Snow Leopard -> app store -> Lion. You are correct.
Edit 2: And as usual, loading those things up with memory and a SSD can make a HUGE difference and add years onto it's useful life. I'm talking $150 or less.
litesout (01-14-2015)
Old 01-14-2015, 10:23 AM
  #357
stogie1020's Avatar
Litesout, depending on how much "stuff" she has, you can just find a cloud storage service like Google drive or dropbox to upload it to for backup purposes. Negates the need for an external hdd if you have less than 3-5GB (Dropbox) or 15GB (GoogleDrive) of actual data.
Old 01-14-2015, 11:14 AM
  #358
Oliver!!!
litesout's Avatar
Thanks guys. I was afraid the interim update would be required. Oh well, still better than buying a new machine.
Stogie, I had completely forgotten about cloud storage. I've got Dropbox set up on it already. We used to use that before I got Plex set up. Heck, she could probably get it all backed up onto a flash drive for that matter. I don't think its that much.
How does the upgrade to Snow Leopard work? Do you have to burn it to disk and install it that way or is it just a .dmg that I can mount and install directly? I'm assuming future updates will install through the app store. Also, will she need to track down any licenses for Office or any other installed software before we do this?
Old 01-14-2015, 11:32 AM
  #359
Sanest Florida Man
#1 STUNNA's Avatar
You'll need an install disc for SL. I got one lying around if you want it. or there are other ways
Old 01-14-2015, 11:47 AM
  #360
maharajamd's Avatar
Mac OS X 10.6 Snow Leopard - Apple Store (U.S.)
Just buy it as it's $20. The upgrade to Lion is done online via the app store.
Quick Reply: Apple: macOS formerly OS X News and Discussion Thread
